Attila The Gel Posted September 7, 2009 Share Posted September 7, 2009 Hello, Anyone knows a way to put the total number of a block used in a drawing in the block itself? This is what I'm trying to do: Got this block called 'Border' with some attributes inside it. I Used the block 'Border' 12 times. So I would like to see the number '12' in each block. and when I copy or insert another 'Border' in this drawing. All the blocks must contain 13 instead of 12. And when I delete it must update (with regen or automatically, it doest really mather). Anyone got an Idea? I tried to find it in field but no success. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 7, 2009 Share Posted September 7, 2009 This is sort of similar: http://www.cadtutor.net/forum/showthread.php?t=37639 Quote Link to comment Share on other sites More sharing options...
Attila The Gel Posted September 8, 2009 Author Share Posted September 8, 2009 Thx, Lee It didn't work because after I select the block, this lisp asks to select a polyline and here's where it goes wrong: Command: BLKUPD Select Block: Select Polyline: > Command: Command: BLKUPD Select Block: Select Polyline: ; error: bad argument type: lselsetp nil could you moddify this lisp to do only the COUNT thing. many thanx, After this I have another question for you. ps: LOL I have a feeling that Acad isn't complete without you . Many thanks for the feedback Hopefully this is more reliable: ;; Block Attribute Updater by Lee McDonnell 06.07.2009 (defun c:blkUpd (/ ins wid hgt bEnt bObj pEnt pObj MiP MaP win num ) (vl-load-com) ;;<< Tag Names must be Capitalised! >> (setq ins "COUNT") ;; << Instances Tag (setq Wid "X-WIDTH") ;; << Width Tag (setq Hgt "Y-HEIGHT") ;; << Height Tag (if (and (setq bEnt (car (entsel "\nSelect Block: "))) (eq "AcDbBlockReference" (vla-get-ObjectName (setq bObj (vlax-ename->vla-object bEnt)))) (eq (vla-get-HasAttributes bObj) :vlax-true) (setq pEnt (car (entsel "\nSelect Polyline: "))) (wcmatch (cdr (assoc 0 (entget pEnt))) "*POLYLINE")) (progn (vla-getBoundingBox (setq pObj (vlax-ename->vla-object pEnt)) 'MiP 'MaP) (mapcar (function (lambda (Obj) (putxdat Obj "LMACUPD" (vl-prin1-to-string (list (vla-get-Handle pObj) (vla-get-Handle bObj)))))) (list pObj bObj)) (setq win (mapcar 'vlax-safearray->list (list MiP MaP)) num (sslength (ssget "_X" (list (cons 0 "INSERT") (cons 2 (vla-get-Name bObj)) (cons 66 1))))) (foreach Att (vlax-safearray->list (vlax-variant-value (vla-getAttributes bObj))) (cond ((eq ins (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos num 2 0))) ((eq Wid (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos (- (caadr win) (caar win)) 2 2))) ((eq Hgt (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos (- (cadadr win) (cadar win)) 2 2)))))) (princ "\n<< Incorrect Selection >>")) (princ)) (defun c:BlkUpdshow (/ gr ent xtyp xval Objlst) (while (and (setq gr (grread t 13 2)) (eq 5 (car gr))) (if (setq ent (car (nentselp (cadr gr)))) (progn (vla-getXdata (vlax-ename->vla-object ent) "LMACUPD" 'xtyp 'xval) (if (and xtyp xval) (mapcar (function (lambda (x) (redraw x 3))) (setq Objlst (mapcar 'handent (read (vlax-variant-value (cadr (vlax-safearray->list xval))))))))) (if Objlst (mapcar (function (lambda (x) (redraw x 4))) Objlst)))) (princ)) (defun BlkUpdr (Reac Args / ins wid hgt blk ss xtyp xval hand pObj MiP MaP bObj win num) ;;<< Tag Names must be Capitalised! >> (setq ins "COUNT") ;; << Instances Tag (setq Wid "X-WIDTH") ;; << Width Tag (setq Hgt "Y-HEIGHT") ;; << Height Tag (if (vl-position (car Args) '("GRIP_STRETCH" "GRIP_MOVE" "GRIP_SCALE" "GRIP_ROTATE")) (if (setq ss (cadr (ssgetfirst))) (progn (vla-getXdata (vlax-ename->vla-object (ssname ss 0)) "LMACUPD" 'xtyp 'xval) (if (and xtyp xval) (progn (setq hand (mapcar 'handent (read (vlax-variant-value (cadr (vlax-safearray->list xval)))))) (vla-getBoundingBox (setq pObj (vlax-ename->vla-object (car hand))) 'MiP 'MaP) (setq bObj (vlax-ename->vla-object (cadr hand)) win (mapcar 'vlax-safearray->list (list MiP MaP)) num (sslength (ssget "_X" (list (cons 0 "INSERT") (cons 2 (vla-get-Name bObj)) (cons 66 1))))) (foreach Att (vlax-safearray->list (vlax-variant-value (vla-getAttributes bObj))) (cond ((eq ins (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos num 2 0))) ((eq Wid (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos (- (caadr win) (caar win)) 2 2))) ((eq Hgt (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos (- (cadadr win) (cadar win)) 2 2))))))))))) (defun putxdat (Obj App Data / ent type1 valeur) (setq xtype (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbInteger '(0 . 1)) '(1001 1000)))) (setq xval (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbVariant '(0 . 1)) (list App Data)))) (vla-setXData Obj xtype xval)) (vl-load-com) (if *lmac-Block* (vlr-remove *lmac-Block*) (setq *lmac-Block* nil)) (setq *lmac-Block* (vlr-command-Reactor nil (list (cons :vlr-CommandEnded 'BlkUpdr)))) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 8, 2009 Share Posted September 8, 2009 I said it was similar not the solution to your problem. Quote Link to comment Share on other sites More sharing options...
Attila The Gel Posted September 8, 2009 Author Share Posted September 8, 2009 I know, but I wanted to try your lisp anyway to see if maybe the count attribute would work. Quote Link to comment Share on other sites More sharing options...
