gilsoto13 Posted September 24, 2009 Share Posted September 24, 2009 Well, I don´t know if a grabbed this lisp from here or other forum, in the first case it must be posted somewhere, but in the second case, it will work for some people to fix some drawings... this lisp will allow you to select a folder through an explorer dialog box, and will open each dwg in that folder and set list of variables you can easily add to the code, you'll see the current list will change each drawing units, mirrtext and plinegen... you can set your own variables and values as required. Thanks to "Tony Tanzillo" for this useful batch lisp. I tested it and works. I don´t think it will allow any extra autocad commands, but at least works for setting variables into multiple drawings. Also, thank you Lee Mac, Alan Thompson and Gilles Chanteau for all your support. BATCH.LSP Quote Link to comment Share on other sites More sharing options...
