TheBrain Posted October 1, 2009 Share Posted October 1, 2009 I've got a dynamic block of a line with some text attributes. I want to create a VBA script which inserts the block at a certain point (which works, this is the easy part), changes the attributes of the block (ie. change the text) and moves the endpoint of the line to a specific point. I can see the attributes in the properties of the block, but I can't seem to access them (blockRefObj.HasAttributes = False). The second problem is the placement of the end point of the line, the only accessible coordinate of the block seems to be the insertionpoint... Quote Link to comment Share on other sites More sharing options...
