4Lester Posted October 9, 2009 Share Posted October 9, 2009 Is there a way to join a whole bunch of small line segments into one line in R14? Thanks in advance Lester Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 9, 2009 Share Posted October 9, 2009 Is there a way to join a whole bunch of small line segments into one line in R14? Thanks in advance Lester pedit (will make plines) or the old Glue.lsp Quote Link to comment Share on other sites More sharing options...
Strix Posted October 10, 2009 Share Posted October 10, 2009 if you don't want to use a lisp, and you don't have too many to do, the quickest way may be to draw a new line over the top, use a window ERASE, and use shift to deselect the new line Quote Link to comment Share on other sites More sharing options...
Coosbaylumber Posted October 16, 2009 Share Posted October 16, 2009 Is there a way to join a whole bunch of small line segments into one line in R14? Thanks in advance Lester Biggest question at this point is do the little bitty line segments actually touch one another, or are they just looking close, and about .005 units apart then? Fr if they touch one another, you can use the PEDIT combine via boxing in command. And you then got one biggie and jagged line. A friend of mine has DataCAD and he uses their combine lines feature, when the line ends are near to one another, but still not perfectly touching. When I look at his drawings in Autocad, those lines do not appear. Wm. Quote Link to comment Share on other sites More sharing options...
