Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2007
    Oct 2009
    1
    Default flat helix pattern for laser cutting
    Hi All
    I have a 3d design of a tapered helix pattern which I need to make out of sheet metal. I would like to laser cut the pattern out of the flat sheet and then roll into the cone.
    I have a dwg file of the 3d mesh and I would like to know how to make this into a flat pattern that I can send as a dwg file to the laser cutting machine.
    Can I open up the 3d mesh to be flat?
    Can anyone help
    many thanks
    Dave
    Full Member
    AutoCAD 2009
    Aug 2009
    54
    Dave,
    Is the mesh predetermined in a flat sheet or will that be part of the laser cut?
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    291
    Hi dbes3d,
    sorry I cannot upload the unrolled pattern (the dwg has 1MB).
    Please send me an email - scj.schulz(at)t-online.de - and I'll send you the drawing.
    Regards
    Jochen
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    Quote Originally Posted by dbes3d View Post
    Hi All
    Can anyone help
    many thanks
    Dave
    Many of the laser "cutting" machines today (or past ten years) do not recognize all Autocad commands nor text in their software. They revert back to what was OK in the 1990's. Thus you need to state for translation in basic lines. If you can get your work to a HP-GL language, then it ought to fly.
    Wm.
  1. Contour Flange to Flat Pattern
    By eweber in forum Autodesk Inventor
    Last Post: 29th May 2009, 02:06 am
  2. Sheet Metal, Flat Pattern
    By kam3 in forum Autodesk Inventor
    Last Post: 15th Apr 2009, 10:12 pm
  3. Flat Pattern Sheet metal.
    By Rob123 in forum Autodesk Inventor
    Last Post: 16th Feb 2009, 08:10 am
  4. Flat Pattern in Inventor 2008.
    By REDHEADEDCHIMP in forum Autodesk Inventor
    Last Post: 3rd Oct 2007, 02:13 pm
  5. "Explode" 3D object into flat cutting pattern shap
    By VBAjedi in forum AutoCAD Drawing Management & Output
    Last Post: 13th Mar 2006, 11:24 am
