Good morning,
Now that I can write my comma delimited file I'd like to load it.
I've searched around, but haven't turned anything up that readily makes sense of what I want.. which surprises me.
Right now my delimiter is a , with no space on either side.. does that make it easier or harder?
I know there is some sort of command for reading a string character by character.. but haven't located it as of yet.
Thanks for any and all help,
Andrew
What is the final form you wish for the output the string is being converted to:
    point list
    plain list
    dotted pair
    another string
    something that can be evaluated
Each has to be dealt with differently. -David
Mr. Gile was nice enough to post these one time...
;;; STR2LST
;;; Transforms a string with separator into a list of strings
;;; Author: Gile
;;; Arguments
;;; str = the string
;;; sep = the separator pattern
(defun str2lst (str sep / pos)
 (if (setq pos (vl-string-search sep str))
   (cons (substr str 1 pos)
     (str2lst (substr str (+ (strlen sep) pos 1)) sep)
   (list str)
;;; lST2STR
;;; Returns a string which is the concatenation of a list and a  separator
;;; Author: Gile
;;; Arguments
(defun lst2str (lst sep)
 (if (cadr lst)
   (strcat (vl-princ-to-string (car lst))
       sep
       (lst2str (cdr lst) sep)
Alan thanks!
That looks like exactly what I want, or close enough to it.
I want to read a line and turn it into a list of strings which will be a list of list of strings.
Andrew
Alan thanks!
Andrew
:) You can do exactly that with what I've posted.
(str2lst STRING ",")
