chrisdarmanin Posted November 9, 2009 Share Posted November 9, 2009 is there a command that does that or should i go to the lisp section? Quote Link to comment Share on other sites More sharing options...
ronjonp Posted November 10, 2009 Share Posted November 10, 2009 I threw this together a while back to put text into an mleader. It works with single or multiline text and sorts from top to bottom. The mleader created used the current mleader style.....enjoy (defun c:am (/ newleader pt1 pt2 ss txt x w rjp-getbbwdth) (vl-load-com) (defun rjp-getbbwdth (obj / out ll ur) (vla-getboundingbox obj 'll 'ur) (setq out (mapcar 'vlax-safearray->list (list ll ur))) (distance (car out) (list (caadr out) (cadar out))) ) (if (setq ss (ssget '((0 . "*TEXT")))) (progn (setq txt (apply 'strcat (mapcar 'cdr (vl-sort (mapcar '(lambda (x) (cons (vlax-get x 'insertionpoint) (strcat (vlax-get x 'textstring) " ") ) ) (setq ss (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) ) ) ) (function (lambda (y1 y2) (< (cadr (car y2)) (cadr (car y1)))) ) ) ) ) w (car (vl-sort (mapcar 'rjp-getbbwdth ss) '>)) txt (apply 'strcat (mapcar 'chr (reverse (cdr (reverse (vl-string->list txt))))) ) ) (mapcar 'vla-delete ss) ) ) (if (and (setq pt1 (getpoint "\nSpecify leader arrowhead location: ")) (setq pt2 (getpoint pt1 "\nSpecify landing location: ")) ) (progn (command "._MLEADER" pt1 pt2 "") (setq newleader (vlax-ename->vla-object (entlast))) (vla-put-textstring newleader txt) (vla-put-textwidth newleader w) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
chrisdarmanin Posted November 11, 2009 Author Share Posted November 11, 2009 Perfect Thanks!!!!!!! Quote Link to comment Share on other sites More sharing options...
JBullseye74 Posted November 11, 2009 Share Posted November 11, 2009 This will come in handy thanks :-) Quote Link to comment Share on other sites More sharing options...
ronjonp Posted November 11, 2009 Share Posted November 11, 2009 Glad you like it guys....it saved me a ton of time already Quote Link to comment Share on other sites More sharing options...
gunjubasich Posted October 8, 2022 Share Posted October 8, 2022 On 11/10/2009 at 11:39 PM, ronjonp said: I threw this together a while back to put text into an mleader. It works with single or multiline text and sorts from top to bottom. The mleader created used the current mleader style.....enjoy (defun c:am (/ newleader pt1 pt2 ss txt x w rjp-getbbwdth) (vl-load-com) (defun rjp-getbbwdth (obj / out ll ur) (vla-getboundingbox obj 'll 'ur) (setq out (mapcar 'vlax-safearray->list (list ll ur))) (distance (car out) (list (caadr out) (cadar out))) ) (if (setq ss (ssget '((0 . "*TEXT")))) (progn (setq txt (apply 'strcat (mapcar 'cdr (vl-sort (mapcar '(lambda (x) (cons (vlax-get x 'insertionpoint) (strcat (vlax-get x 'textstring) " ") ) ) (setq ss (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) ) ) ) (function (lambda (y1 y2) (< (cadr (car y2)) (cadr (car y1)))) ) ) ) ) w (car (vl-sort (mapcar 'rjp-getbbwdth ss) '>)) txt (apply 'strcat (mapcar 'chr (reverse (cdr (reverse (vl-string->list txt))))) ) ) (mapcar 'vla-delete ss) ) ) (if (and (setq pt1 (getpoint "\nSpecify leader arrowhead location: ")) (setq pt2 (getpoint pt1 "\nSpecify landing location: ")) ) (progn (command "._MLEADER" pt1 pt2 "") (setq newleader (vlax-ename->vla-object (entlast))) (vla-put-textstring newleader txt) (vla-put-textwidth newleader w) ) ) (princ) ) Good afternoon. Can you tweak the code a bit? I've been sitting here for a day and a half and still can't figure it out. I would like it to take the original location points instead of selecting the arrow location. And leave the second action (specify the landing location) as it is For example, like this picture Quote Link to comment Share on other sites More sharing options...
