Hello,
I have a question about macros on tool palettes.
If there is a button on a tool palette with this macro:
^C^C^P(command "_AecbDuctFittingAdd" "_ty" "cross")
after using the macro, if i right click on the screen, the shortcut menu appears, and if i look under "recent input", i will be able to see this (command "_AecbDuctFittingAdd" "_ty" "cross").
I am wondering if there is a way to give the maro a name to show in the recent input list, and if not, can the macro be hidden from the recent input list?
Thanks.
Create a new command using that AutoLISP statement in your acaddoc.lsp file (use the name you want):
(defun c:[color=blue]DuctFittingCross[/color]
and replace the macro by:
^C^C[color=blue]DuctFittingCross[/color]
This way the "name" DuctFittingCross will appear in list.
Hi, Thanks for your response.
Is there any other way besides making a Lisp file? Is there something that can be added to the macro that will create a display name, or hide that macro code?
Thanks again
Not sure that there is a way to accomplish your request - you may try to use the above as associated macro (even if is using AutoLISP also):
^C^C^P(defun c:DuctFittingCross (command "_AecbDuctFittingAdd" "_ty" "cross") (princ)) DuctFittingCross
This way, at least, will avoid having an extra file to manage.
Regards,
