How do you access dynamic block parameters?
Maybe a silly question, but how do you get a rotation from a dynamic block?
My block has scale and rotation dynamic properties in it. The Rotation shows in the Properties bar as Angle1. How can I retrieve this in lisp?
Ultimately I want to realign the rotation of the block to another object I select e.g. line, polyline etc..
Thanks in advance
example:
(defun c:test ( / ent )
 (vl-load-com)
 (if (setq ent (car (entsel "\nSelect Block: ")))
   (mapcar
     (function
       (lambda (property)
         (vlax-get property 'value)))
     (vlax-invoke
       (vlax-ename->vla-object ent) 'getDynamicBlockProperties))))
Thanks in advance
I hope this will allow you to change parameters
(just one at a time - sorry, not tested)
(defun C:cang(/ ang blk blkname cparam props ss)
 (setq blkname "TestBlock" ;<--change block name here
cparam "Angulo");<--change parameter name here
 (setq ang (getreal "\nEnter angle in degrees: ")
ang (/ (* pi ang) 180)
 (if (setq ss (ssget ":S" (list
	      (cons 0 "INSERT")
	      (cons 2 (strcat blkname ",`*U*")))))
   (setq blk (vlax-ename->vla-object (ssname ss 0)))
   (setq props (vlax-safearray->list
                     (variant-value
                     (vla-getdynamicblockproperties blk))))
(foreach param props
(if (eq cparam (vla-get-propertyname param))
   (vlax-put-property param "Value" (vlax-make-variant ang 5))
 (vla-update blk)
(vl-load-com)
~'J'~
Thanks guys it gives me something to work with! May God bless you with a pay rise!
Your welcome :)
