cedwards Posted November 30, 2009 Share Posted November 30, 2009 I was wondering if there is a way to copy a Viewport(from layout to layout) & keep the VP Frozen Layers frozen. Thanks, Quote Link to comment Share on other sites More sharing options...
todouble22 Posted November 30, 2009 Share Posted November 30, 2009 I was wondering if there is a way to copy a Viewport(from layout to layout) & keep the VP Frozen Layers frozen. Thanks, you're working in Paper Space so in the layout tab create a copy, I think you've already done this correct? in the layer manager click the box that says freeze or thaw in current viewport. that should dothe trick Quote Link to comment Share on other sites More sharing options...
tonybolony Posted February 25, 2010 Share Posted February 25, 2010 this would only work if you want to copy all the viewports - what if you want to copy a single viewport (showing a keyplan for instance) into a drawing with multiple tabs. everytime you paste it, the frozen layers unthaw. i cannot freeze those layers as they are used in the floor plans. any thoughts?? thanks tony Quote Link to comment Share on other sites More sharing options...
SGarcia Posted February 28, 2010 Share Posted February 28, 2010 If you are copying them into different sheets you could make a layer state for them so when you applied it it would freeze those specific layers. Quote Link to comment Share on other sites More sharing options...
rkent Posted February 28, 2010 Share Posted February 28, 2010 I was wondering if there is a way to copy a Viewport(from layout to layout) & keep the VP Frozen Layers frozen. Thanks, There may be better ways but you can make the VP a block, then insert it, explode, and the layers will be set the same. Quote Link to comment Share on other sites More sharing options...
