label line with layer name and place text
sroberts
Yes it will save me a lot of time
thank you
How about fields
(defun alg-ang	(obj pnt)
 (angle '(0. 0. 0.)
 (vlax-curve-getfirstderiv
   obj
   (vlax-curve-getparamatpoint
     obj
     pnt
(defun C:LL (/ *error* acsp adoc ang fld midp mtx rot sset txtpt)
 (defun *error*  (msg)
   (if
     (vl-position
msg
'("console break"
  "Function cancelled"
  "quit / exit abort"
      (princ "Error!")
      (princ msg)
      (vla-endundomark
(vla-get-activedocument
       (vlax-get-acad-object)
 (or adoc
     (setq adoc
 (if (and
(= (getvar "tilemode") 0)
(= (getvar "cvport") 1)
   (setq acsp (vla-get-paperspace adoc))
   (setq acsp (vla-get-modelspace adoc))
 (vla-startundomark
adoc
(if (setq sset (ssget "_:L" (list (cons 0 "*LINE,ARC,CIRCLE,ELLIPSE"))))
 (foreach obj
   (mapcar 'vlax-ename->vla-object
     (vl-remove-if 'listp
       (mapcar 'cadr (ssnamex sset))))
(if (not (eq "AcDbArc"  (vla-get-objectname obj)))
(setq midp (vlax-curve-getclosestpointto obj
     (vlax-curve-getpointatparam obj
  ( / (- (vlax-curve-getEndParam obj)
  (vlax-curve-getStartParam obj)) 2))
	(vlax-curve-getpointatdist obj
  ( / (vla-get-arclength obj) 2)))
(setq ang (alg-ang obj midp))
(if (> pi ang (/ pi 2))
       (setq ang (+ ang pi))
(if (> (* pi 1.5) ang pi)
     (setq rot (+ ang (/ pi 2)))
   (setq txtpt (polar midp rot
	       (if (zerop (getvar "dimtxt"))
		 0.1
		 (/ (getvar "dimtxt") 2)))
(setq fld (strcat "%<\\AcObjProp Object(%<\\_ObjId "
		  (itoa (vla-get-objectid obj))
		  ">%).Layer>%")
 	 (setq mtx (vlax-invoke
	     acsp 'AddMText midp 0.0 fld)
 (vlax-put mtx 'AttachmentPoint
	   8
   (vlax-put mtx 'InsertionPoint
	   txtpt
        (vlax-put mtx 'Rotation
	   ang
(princ "\n\t\t\tType LL to label curves with layer name\t")
(prin1)
(vl-load-com)
~'J'~
How about fields
 (angle '(0. 0. 0.)
      obj
        obj
        pnt
   (if
     (vl-position
   msg
   '("console break"
     "quit / exit abort"
      (princ "Error!")
      (princ msg)
      (vla-endundomark
 (or adoc
     (setq adoc
 (if (and
 (vla-startundomark
adoc
 (foreach obj
            0.1
             ">%).Layer>%")
          8
          txtpt
          ang
(prin1)
(vl-load-com)
~'J'~
This works great too. I did have to revise one thing the LL is another command in civil 3d cad.
I must say this is my first time asking for a specific program and all of your responses have been very helpful and will save me so much time. I really do appreciate it, and i hope others will too.
Thanks Sherry
  • 2 years later...
Hai,
This is a super lisp. Can it make the label to be at the end of the line with text justification as middle left and also can we get the label for blocks either block name or layer on which it is inserted.
Thanks
Cadworker
  • 2 years later...
Helloooo guys cad-world. I like the lisp LAYTEXT. Is it possible to put more than one text?
If a line has a distance X, 2 are inserted or more texts. Is it possible?
Thank
