rob150588 Posted December 4, 2009 Share Posted December 4, 2009 Hello, I've got a lisp routine that converts an array of 3D faces into a 3D solid, f2s.lsp...if anyone knows it ? The routine worked perfectly on AutoCAD 2009, but fails to run on 2010 (64bit)...it just hangs on an unknown error until I cancel the funtion. The error issued by the command line is: ; error: Function cancelled Could anyone shed any light into why this might happen, wondering if it's a problem with AutoCAD 2010, or if it's just because it's 64bit ? Cheers. Quote Link to comment Share on other sites More sharing options...
David Bethel Posted December 4, 2009 Share Posted December 4, 2009 I'd probably post this over on the Autodesk's Autocad Customization NG. Bill Gilliss hung out over there. -David Quote Link to comment Share on other sites More sharing options...
rob150588 Posted January 8, 2010 Author Share Posted January 8, 2010 Ok, Thanks David. Quote Link to comment Share on other sites More sharing options...
aaronbig Posted February 22, 2010 Share Posted February 22, 2010 if you still need it solved... i was in the same situation like you. windows7 64bit acad 2010. f2s.lsp made the same error... --- here is how i got to the solids... unfortunately not joined. this will be an other task. i have to do that later... --- acad 2010: - Modify -> Mesh Editing -> Extrude Face (or easy: EXTRUDE) - select the objects you want to extrude (which become solids) - specify the hight of extrusion or (direction/path/taper angle) i used direction... therefore click start & endpoint the 3d faces will be converted into solids... if you want to save the 3d faces you should have to make copies. e voila :-) hope it helps Quote Link to comment Share on other sites More sharing options...
rob150588 Posted February 22, 2010 Author Share Posted February 22, 2010 That's excellent, thanks very much. It seems to have a bit of an issue with the orientation of some faces but for the mostpart it works. Again, thank you very much. Quote Link to comment Share on other sites More sharing options...
rob150588 Posted March 8, 2010 Author Share Posted March 8, 2010 Sorry for resurecting an old thread... Having emailed Bill Gilliss regarding the f2s routine, he has now fixed it: I finally tracked down the problem in F2S.lsp (AutoCAD had changed the AREA command) and attach version 1.10 which should now work with all versions of AutoCAD. - Bill Gilliss. I've attached the new one. Hopefully it helps some more people too. F2S.lsp Quote Link to comment Share on other sites More sharing options...
David Bethel Posted March 8, 2010 Share Posted March 8, 2010 Don't be sorry! A lot of people still use f2s. I'm glad Bill fixed it! -David Quote Link to comment Share on other sites More sharing options...
