Hi all,
I need to extract attributes from dynamic blocks to excel.
The attout command is good but i need more informations like visibility state and so on...
The extraction wizard export all this informations but not the Handle...
So what i need is:
Export all the attributes
+handle id of the blocks
+visibility state
+Real blockname (with attout command the block names look like *U18, *U72 ....)
Maybee somebody has already a lisp routine who do this :)
Hope somebody can help me, it's urgent. Thanks in advance for your support!
In attachment the drawing containing 3 dynamic blocks.
The attributes of those blocks are different.
Astro give me the CSV format for returned data.
Feel free to direct contact me.
See attached file
!!!wheretosend.txt
Thank you for your help :D.
In attachment the files.
The one starting with xls is an excel extracted with the extraction wizard. Just rename it to xls. (Cannot upload xls...)
The other one is with -attout command
OLDdrawing2.txt
XLSOLDdrawing2.txt
when i execute the command i have foloowing error
Command: _appload GET DATA FROM DYN BLOCK.LSP successfully loaded.
Command: prompt DYN-DAT at the command line
Command:
Command: dyn-dat
; error: no function definition: LIST$2CVS
Command:
(defun list$2cvs (#lst)
(if (not ( listp #lst))
(setq #lst (list #lst))
(apply 'strcat
(cons (car #lst)
(mapcar '(lambda (str) (strcat "," str))
(cdr #lst)
) ;_mapcar
) ;_cons
) ;_apply
) ;_ string-list2cvs
;;;usage(string-list2cvs '("One" "Two" "Three"))
;;;->"One,Two,Three"
I did it before your post
Very interesting tread, very useful, however never use a word like Standard again :D This is a fictious idea that has never been realized. Kind of like a 'Go By Job' yet another engineer/proposal idea that does not exsist in real life.
Hi Dany , what I mean by
Is about the CSV format .
As I ask him to show the way it want the csv to be, but I end the lisp before he post both TXT and XLS files.
Just making a Joke Bro. I did understand your thread and thought there was useful information in it
Hi Danny , as English is not my native idiom , I did not understood your message.
All clear.
(apply 'strcat
(cons (car #lst)
(cdr #lst)
) ;_mapcar
) ;_cons
) ;_apply
I added this to the code but have still an error :oops:
Command: dyn-dat
; error: bad argument type: lselsetp nil
Command:
Maybe i did something wrong?
Test it , please.
;; Design by Gabo CALOS DE VIT from CORDOBA ARGENTINA
;;;    Copyleft 1995-2009 by Gabriel Calos De Vit
;; DEVITG@GMAIL.COM
(DEFUN guarda-lista-csv-w  (lista
                           ar
;;;                            nombre-archivo
 (SETQ nombre-archivo
        (STRCAT (GETVAR "dwgprefix")
                (VL-FILENAME-BASE (GETVAR "dwgname"))
                ".csv"))
 (SETQ ar (OPEN nombre-archivo "w"))
 (FOREACH texto  lista
   (WRITE-LINE texto ar)
 (CLOSE ar)
;;;Juerg Menzi
;;;MENZI ENGINEERING GmbH, Switzerland
;;;http://www.menziengineering.ch
; == Function MeGetAtts
; Reads all attribute values from a block
; Arguments [Typ]:
;   Obj = Object [VLA-OBJECT]
; Return [Typ]:
;   > Dotted pair list '(("Tag1" . "Val1")...)
[list]
; Notes:
;   None
(defun MeGetAtts (Obj)
 (mapcar
 '(lambda (Att)
   (cons
    (vla-get-TagString Att)
    (vla-get-TextString Att)
  (vlax-invoke Obj 'GetAttributes)
;; TASK TO DO
;;;Export all the attributes
;;;+handle id of the blocks
;;;+visibility state
;;;+Real blockname
(defun GET-NAME+HANDLE+VISIBLE+ATTs ( /
                 ACAD* ADOC ALL-INSERTED-CSV-LIST ALL-INSERTED-DATA-LIST ATT-PAIR-LIST CSV-LIST DATA-LIST DATA-LIST< HANDLE nombre-archivo INSERTED-CSV INSERTED-LIST INSERTED-SS NAME VISIBLE
(vl-load-com)
(setq acad* (vlax-get-acad-object)) ;_ ACAD
(setq adoc (vla-get-activedocument acad*))  ;_ DWG active
(setq insertED-SS (ssget "_X" '(( 0 . "insert"))));_ all inserted blocks
(setq inserted-list (mapcar 'vlax-ename->vla-object (vl-remove-if-not '(lambda(x)(= (type x) 'ENAME)) (mapcar 'cadr (ssnamex insertED-SS)))));_ a list of inserted
(setq all-inserted-csv-list nil)
(setq all-inserted-data-list nil)
(foreach inserted inserted-list
(setq data-list nil)
(setq csv-list nil)
(setq name (vla-get-EffectiveName inserted))
(setq data-list (cons (cons "NAME" name) data-list))
(setq handle (vla-get-Handle  inserted))
(setq data-list (cons (CONS "HANDLE"  handle) data-list))
(setq visible (if  (vla-get-Visible inserted)
 "visible"
 "no visible"
   );_ if
     );_ visible
(setq data-list (cons (cons "VISIBLE"  visible) data-list))
(setq csv-list (reverse(list name  handle visible ) ))
 (if (vla-get-hasAttributes inserted )
(setq att-pair-list  (MeGetAtts inserted))
(foreach att-pair att-pair-list
  (setq data-list ( cons att-pair data-list))
  (setq csv-list (cons (Cdr att-pair) csv-list))
);_ progn
   );If has attribute
(setq inserted-csv (list$2cvs (reverse csv-list)))
(setq data-list<  (reverse data-list))
(setq all-inserted-data-list (cons  data-list< all-inserted-data-list))
(setq all-inserted-csv-list (cons  inserted-csv all-inserted-csv-list))
);_ foreach inserted
(setq blk-qty (length all-inserted-csv-list))
(guarda-lista-csv-w all-inserted-csv-list)
 (alert (strcat "\n Data form  : \n " (Itoa blk-qty) "   BLOCKS  \n has been sent to .. \n" nombre-archivo ))
);_ defun
(defun c:dyn-dat ()
 (GET-NAME+HANDLE+VISIBLE+ATTs)
(apply 'strcat
(cons (car #lst)
(cdr #lst)
) ;_mapcar
) ;_cons
) ;_apply
(prompt "prompt DYN-DAT at the command line")
;|«Visual LISP© Format Options»
(72 2 1 0 nil "end of " 100 20 2 0 0 nil T nil T)
;*** DO NOT add text below the comment! ***|;
Thanks it works now :)
I have some remarks,
-is it possible to get the outputformat to an xls with tab delimited tabs an titles on the header?
-when the handle id is something like 48E8, excel interprets it like 4.80E+09 so --> 4800000000
with -attout command the handle is '48E8 and then excel recognize it
-last one is, i need the visibility state of my dynamic block. Not if it's visible or not. So my dynamic block can have up to 20 visibility states e.g. and i need them in the excel.
Thanks again for your good work :D
If you open the csv by excell , no need to be TAB delimited.
About header can be so , I will fix.
If you open the csv by excell, it will show as text, see attached image.
As i do not do dyn blocks, I do not know what the visibility state covers or mean, and I understood that it is a feature of the block, no the inserted block or blockreference.Please clear it .
My comments in blue
