Hi friends
How I can put each excel column to linear array ?
How I can put each excel raw to linear array ?
for example 10 row and 4 column
Thanks Mr.Lee
I read these files , they are very detailed and will solve my problem.
Mr.Lee I can read a lisp file but I'm not a lisp programmer ,
I 've started lisp programming since two week ago but now I can combine these lisp file with a vba cod or convert them .
thanks you very much and have a good time .
Thanks Mr.Lee
Hmm... I think they would need to be re-written into VBA... not converted - no easy (or quick) task.
Hi friends
Another way
(defun readrow (xlsheet rownum / c1 cel cels celvalue cols r1 rowdata xlrange xlrow)
 (vlax-invoke-method xlsheet "Activate")	  ;optional
 (setq xlrange (vlax-get-property xlsheet "UsedRange"))
 (setq	xlrow	(vlax-variant-value
	  (vlax-get-property
	    (vlax-get-property
	      xlrange
	      "Rows")
	    "Item"
	    rownum)))
 (setq cols (vlax-get-property
       (vlax-get-property xlrange "Columns")
       "Count")
 (vlax-invoke-method xlrange "Activate")	  ;optional
 (vlax-invoke-method xlrange "Select")	  ;optional
 (setq cels (vlax-get-property xlsheet "Cells"))
 (setq	r1   rownum				  ; given row number
c1   1					  ; initial column number in row
 (while (<= c1 cols)
   (setq cel (vlax-variant-value
	(vlax-get-property
	  cels
	  "Item"
	  ;; row number :
	  (vlax-make-variant r1 vlax-vblong)
	  ;; column number :
	  (vlax-make-variant c1 vlax-vblong))))
   (setq celvalue (vlax-variant-value (vlax-get-property cel "Value2")))
   (setq rowdata (cons (vl-princ-to-string celvalue) rowdata))
   (setq c1 (1+ c1 )))
   (reverse rowdata)
(defun readcolumn (xlsheet colnum / c1 cel cels celvalue columndata r1 rows xlrange xlrow)
	  (vlax-get-property
	    (vlax-get-property
	      xlrange
	      "Rows")
	    "Item"
	    colnum)))
 (setq rows (vlax-get-property
       (vlax-get-property xlrange "Rows")
       "Count")
 (setq	r1  1 				                  ; initial row number in column
c1  colnum					  ; given column number
 (while (<= r1 rows)
	(vlax-get-property
	  cels
	  "Item"
	  ;; row number :
	  ;; column number :
   (setq columndata (cons (vl-princ-to-string celvalue) columndata))
   (setq r1 (1+ r1 )))
   (reverse columndata)
;; Usage :
(defun C:GRD  (/
	*error*
	C1
	Cel
	Cels
	Celvalue
	Colnum
	Datalist
	Excelapp
	Filepath
	Findrang
	Findrow
	Lastcell
	R1
	Rownum
	Sht
	Shtnum
	Wbk)
 (defun *error*  (msg)
   ;; close workbook w/o saving changes
   (vl-catch-all-apply
     'vlax-invoke-method
     (list Wbk "Close")
   ;; quit Excel
   (vl-catch-all-apply
     'vlax-invoke-method
     (list ExcelApp "Quit")
   ;; clean up of memory
   (mapcar
     (function
(lambda	(x)
  (vl-catch-all-apply
    (function (lambda ()
		(if (not (vlax-object-released-p x))
		  (vlax-release-object x)
     (list Cel LastCell Cels FindRow FindRang Sht Wbk ExcelApp)
   (setq Cel nil
  LastCell nil
  Cels nil
  FindRow nil
  FindRang nil
  Sht nil
  Wbk nil
  ExcelApp nil
   (gc)
   (gc)
 (setq	FilePath (getfiled "Select Excel file to read data:"
		   (getvar "dwgprefix")
		   "xls"
		   16
 (initget 6)
 (setq ShtNum (getint "\nEnter a sheet number <1>: "))
 (if (not ShtNum)
   (setq ShtNum 1))
 (initget 6)
 (setq RowNum (getint "\nEnter a row number <1>: "))
 (if (not RowNum)
   (setq RowNum 1))
   (initget 6)
 (setq ColNum (getint "\nEnter a column number <1>: "))
 (if (not ColNum)
   (setq ColNum 1))
 (setq ExcelApp (vlax-get-or-create-object "Excel.Application"))
 (vla-put-visible ExcelApp :vlax-true)		  ;or :vlax-false for invisible mode
 (setq	Wbk (vl-catch-all-apply
      'vla-open
      (list (vlax-get-property ExcelApp "WorkBooks") FilePath)))
 (setq	Sht (vl-catch-all-apply
      'vlax-get-property
      (list (vlax-get-property Wbk "Sheets")
	    "Item"
	    ShtNum)))
 (vlax-invoke-method Sht "Activate")
 (setq rowlist (readrow Sht RowNum))
 (setq columnlist (readcolumn Sht ColNum))
 (princ "\nRow data: ")
 (print rowlist)
 (princ "\nColumn data: ")
 (print columnlist)
 ;; --> work here with this data after
 (*error* "")
(vl-load-com)
~'J'~
Here is VBA example
~'J'~
Thanks dear fixo
I changed your code and now I can read an excel file that have 7 column and 1420 row , when it worked correctly and finished my project , put it after your code . another time , I thanks very much from you and Mr Lee for your good codes .
Thanks dear fixo
You're welcome
Cheers :)
~'J'~
