fba_sen57 Posted December 16, 2009 Share Posted December 16, 2009 Hi guys... I am trying to create a linetype with an arrow head. The arrowhead is simply from text " Descriptive text: --- Enter linetype pattern (on next line): A,0.5,[" But I got an error stating "Invalid number or bad continuation." Please anyone. Help or any either way to create that particular linetype. Appreciate greatly. Fadzil Quote Link to comment Share on other sites More sharing options...
Tiger Posted December 16, 2009 Share Posted December 16, 2009 I have meved your question to it's own thread, please start a new thread for each new question. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 16, 2009 Share Posted December 16, 2009 Why are you using text? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 16, 2009 Share Posted December 16, 2009 Like this? Constructed using the MKLTYPE command found in Express Tools. Not sure if this command was part of Express Tools for AutoCAD 2004/2005. Quote Link to comment Share on other sites More sharing options...
NBC Posted December 16, 2009 Share Posted December 16, 2009 I used the example given the OP's original post, and used the following in .lin file, and it worked fine. *Arrow,arrow <|--- A,0.5,["<|",STANDARD,S=0.1,R=0.0,Y=-0.05],0.5 Quote Link to comment Share on other sites More sharing options...
fba_sen57 Posted December 17, 2009 Author Share Posted December 17, 2009 Thanks guys. I am using text as I don't know how to create linetype with arrowhead. I am using AutoCAD 2005. Is there any restriction in this version on creating linetype? Its good to know NBC got it using similar A, statement but why I got "invalid number or bad continuation" Quote Link to comment Share on other sites More sharing options...
fba_sen57 Posted December 21, 2009 Author Share Posted December 21, 2009 Hi Guys, Any more help??? I still got that same error as before. I really appreciate it so much... Fadzil Quote Link to comment Share on other sites More sharing options...
fba_sen57 Posted December 21, 2009 Author Share Posted December 21, 2009 I tried MKLTYPE in AutoCAD 2005 but its an "unknown command". Quote Link to comment Share on other sites More sharing options...
CarlB Posted December 21, 2009 Share Posted December 21, 2009 You may get a lin file error if the file doesn't end with a blank line...try that.. Quote Link to comment Share on other sites More sharing options...
fba_sen57 Posted December 23, 2009 Author Share Posted December 23, 2009 Well, I still got that same error eventhough I have added a space -0.1. A, 0.5,[" Any other help??? Fadzil Quote Link to comment Share on other sites More sharing options...
CarlB Posted December 24, 2009 Share Posted December 24, 2009 Could you attach your .lin file? The pattern you posted works for me, so maybe something is wrong with your file. Quote Link to comment Share on other sites More sharing options...
fba_sen57 Posted December 29, 2009 Author Share Posted December 29, 2009 CarlB, I tried to attached the acadiso.lin file but it is considered as invalid filename. So how now? Fadzil Quote Link to comment Share on other sites More sharing options...
CarlB Posted December 29, 2009 Share Posted December 29, 2009 rename the file to have a ".txt" extension Quote Link to comment Share on other sites More sharing options...
Tankman Posted December 29, 2009 Share Posted December 29, 2009 Like this? Constructed using the MKLTYPE command found in Express Tools. Not sure if this command was part of Express Tools for AutoCAD 2004/2005. The command is included in AutoCAD '05 if Express Tools was loaded. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted January 4, 2010 Share Posted January 4, 2010 If you're just embedding characters into a line type give this a try: *removedLink* Need to do update to check for invalid characters Quote Link to comment Share on other sites More sharing options...
