guitarguy1685 Posted January 6, 2010 Posted January 6, 2010 Hi it's me again. I have yet another question. I would like to write a lisp that will draw a leader and insert a dynamic block that has an attribute in it. Before dynamic blocks I used to have to create 2 blocks with insertion points on either the right or left side. I'm sure you know w/ dynamic blocks you can have multple insertion points. My question is: Can I use LISP to change which insertion point to use? Quote
flowerrobot Posted January 6, 2010 Posted January 6, 2010 Are you sure muliple insertion points, I know you multiple base points, Which act the same. Purhaps a file with the Dyn block would help in tired old brain Flower Quote
flowerrobot Posted January 7, 2010 Posted January 7, 2010 Can I use LISP to change which insertion point to use? As i thought no. It only has one insertion point. Yes you can insert it, and change the properties tho.Which is what you need. I belive amsi has the best examples on his site,Which you should be able to do what ever you need. How ever if you get stuck feel free to ask. And just a thought,What you have there looks like a Mleader sort of thing, 2 feilds dynamic with a leader. Fower Quote
