I have this lisp that I pieced together to take a dxf output and rearrange it onto a set of standard layers.
I am getting an error with it bur I was wondering if someone can write it more efficiently??
Thanks
(defun c:DoerVer(/)
(command "_.-layer" "_N" "CCC_DOER_LA0001" "_M" "CCC_DOER_LA0001" "_C" "253" "CCC_DOER_LA0001" "_LW" "0.3" "CCC_DOER_LA0001" "" )
(command "_.-layer" "_N" "CCC_DOER_LA0002" "_M" "CCC_DOER_LA0002" "_C" "7" "CCC_DOER_LA0002" "_LW" "0.3" "CCC_DOER_LA0002" "" )
(command "_.-layer" "_N" "CCC_DOER_LA0003" "_M" "CCC_DOER_LA0003" "_C" "84" "CCC_DOER_LA0003" "_LW" "0.3" "CCC_DOER_LA0003" "" )
(command "_.-layer" "_N" "CCC_DOER_LA0004" "_M" "CCC_DOER_LA0004" "_C" "1" "CCC_DOER_LA0004" "_LW" "0.3" "CCC_DOER_LA0004" "" )
(command "_.-layer" "_N" "CCC_DOER_LA0005" "_M" "CCC_DOER_LA0005" "_C" "2" "CCC_DOER_LA0005" "_LW" "0.3" "CCC_DOER_LA0005" "" )
(command "_.-layer" "_N" "CCC_DOER_LA0006" "_M" "CCC_DOER_LA0006" "_C" "7" "CCC_DOER_LA0006" "_LW" "0.3" "CCC_DOER_LA0006" "" )
(command "_change" "all" ""  "p" "layer" "CCC_DOER_LA0006" "" )
(setq blue(ssget "x" '((62 . 5))))
(command "_change" blue ""  "p" "layer" "CCC_DOER_LA0001" "color" "bylayer" "")
(setq magenta(ssget "x" '((62 . 6))))
(command "_change" magenta ""  "p" "layer" "CCC_DOER_LA0002" "color" "bylayer" "")
(setq green(ssget "x" '((62 . 3))))
(command "_change" green ""  "p" "layer" "CCC_DOER_LA0003" "color" "bylayer" "")
(setq red(ssget "x" '((62 . 1))))
(command "_change" red ""  "p" "layer" "CCC_DOER_LA0004" "color" "bylayer" "")
(setq yellow(ssget "x" '((62 . 2))))
(command "_change" yellow ""  "p" "layer" "CCC_DOER_LA0005" "color" "bylayer" "")
(setq text1(ssget "x" '((8 . "TEXT"))))
(command "_change" text1 ""  "p"  "color" "bylayer" "")
Not sure if this is the best way to tabulate the data, but it should be faster than what you are using.
(defun c:DoerVer (/ *error* Make_Layer Layers obj ss tag)
 (vl-load-com)
 (setq Layers
     ; Old Color    ; New Layer     ; Layer Color ; Layer Lineweight
        '((5   . ("CCC_DOER_LA0001"     253          "030"))
          (6   . ("CCC_DOER_LA0002"       7          "030"))
          (3   . ("CCC_DOER_LA0003"      84          "030"))
          (1   . ("CCC_DOER_LA0004"       1          "030"))
          (2   . ("CCC_DOER_LA0005"       2          "030"))
          (nil . ("CCC_DOER_LA0006"       7          "030")))
 (setq *doc* (cond (*doc*) ((vla-get-ActiveDocument
                              (vlax-get-acad-object)))))
 (defun *error* (msg)
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (defun Make_Layer (lay Col LnW)
   (cond (  (tblsearch "LAYER" lay))
         (  (setq lObj (vla-add (vla-get-Layers *doc*) lay))
            (vla-put-color lObj Col)
            (vla-put-lineweight lObj
              (eval (read (strcat "acLnWt" LnW)))))))
 (mapcar
   (function
     (lambda (x) (apply (function Make_Layer) (cdr x)))) Layers)
 (if (ssget "_X")
     (vlax-for obj (setq ss (vla-get-ActiveSelectionSet *doc*))
       (if (setq tag (assoc (vla-get-color obj) Layers))
         (mapcar
           (function
             (lambda (x y) (vlax-put-property obj x y))) '(color layer)
           (list acByLayer (cadr tag))))
       (if (eq "TEXT" (vla-get-layer obj))
         (vla-put-color obj acByLayer)))
     (vla-delete ss)))
 (princ))
Thanks for that LeeMac. That did the job. One other thing, Part of the output file that I am applying the lisp to creates two green lines that are always 2.25 units apart vertically. I include the dxf to see what i mean. They are both the same colour. Is it possible to select the lower line and move that to layer CCC_DOER_LA0005. This is for a long section.
I also run a modified version of this lisp for a set of cross sections. Each of those cross sections contains the two green lines too. Is it possible to scan the drawing and move the lower green lines to a separate layer to be turned off??
Thanks.
Thanks.
You would have to create an ssget filter using some characteristic of the line - whether it be always at some elevation, or the y-coord is always the same, or perhaps it has a known length.
But picking a single line automatically without any defining characteristics is a nightmare...
OK.
Thanks anyway Lee. Worth a shot.
OK.
Well, I'm not saying that it is impossible - but does the line have any "defining" features that set it aside from other lines that you do not want selected?
Thanks Lee but they are the same line only 2.25 apart. Nothing to distinguish them. No worries.
.. Ok .. :)
