How to apply 3d array...
humaironline
I want to repeat the stair railings by using 3d Array or any other command.
Kindly help me out to do it.
stair = L3' x W8" x h8"
waiting a quick response....
  • Replies 23
  • humaironline
    10
  • stevsmith
    6
  • iskalipsi
    5
  • amit87
    1
Why don't you just copy the objects, select both stantion posts, and use the toe of the step as your base point.
It would probably take more time and to much effort to set up an array, besides this I don't think array can be used to go up at an inclined angle.
its ok stevsmith...but i want to learn the 3d array ....by this problem.
I hope any one will help me soon to solve this issue.
so waiting....
I tried but its not easier, to place on face. cross hair not select face easily..so I need to place a line on every step.
so its better we solve it by array or other useful command.
3D arrays are pretty simple.
Click on 3d Array
Select the object.
Select whether you want a rectangular Array or polar Array.
Rectangular array
Enter number of rows - This is the number of items along the "y" axis
Enter the number of columns - this is the number of items along the "x" axis
Enter the number of levels - this is the number of items along the "z" axis
Specify each distance.
Polar
Enter the number of items in array - how many items do you want
Specify the angle to fill - (+ 275 means anti clockwise 275deg) (-275 means clockwise)
Rotate arrayed object - lets the cpu know if the the objects are to be turned along path of array.
Specify the centre point.
specify your axis - for the objects to be rotated around.
Trust me, I design staircases for a living. Copy is the easier method.
ya....nice...thanks....every one...i have done it by using 2d array....
stevsmith...your last trick is also very good...
now the problem is to draw a continues hand railing...that run on top of every pole.... can any one help to draw spline on them...i tried but it not look good.
you have to orientate the ucs icon to go with the angle of the stair, this will allow you to draw a handrail and extrude it along it's path.
please note that this is only a quick example. I'm at work and don't have the time for a full on tutorial. but it is best to explore ucs manipualtion. It can be a pain at 1st, but it's worth it
Try to draw a 3DPOLY.First point on the top center of your stair baluster then the second on the bottom center. And then use SWEEP for your hand rail.
I want to apply material on inside wall, but when I apply it spread on whole wall. Pls tell me any way to apply separately. see the attachment.
humair.
You could open your Materials pallette, click on the material you want to apply whilst holding the control key and drag it to the face you want to Render.
Hopefully that helps you my friend.
Yah...thats was a good idea...thanks melox...
iskalipsi...see the advice of melox...
thanks....again...now i got ...it..
nice tip.Ill try that. thanks. Can you post a finish picture of your render?
