Ramsden Posted January 19, 2010 Share Posted January 19, 2010 Hello, I currently use a full version of AutoCAD 2009. One thing I was able to do previously was repeat break at point by right-clicking and selecting the repeat function. Now when I try to do that in AuctoCAD 2009, the repeat function will result with just a plain break instead of a break at point. My question is, how do i get this functionality back so that I can repeat break at point as many times as I need to? I use this command many times back to back and hate having to go click on the button from the ribbon menu. Thanks for any help provided. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted January 19, 2010 Share Posted January 19, 2010 add this to your acaddoc.lsp file, it'll be a command then. Invoke the command with Brk-At or BB (defun c:brk-at ( / e1) (setq e1(entsel "Select object: ")) (command "break" e1 "f" pause "@" ) (princ) ) (defun c:bb () (c:brk-at)) Quote Link to comment Share on other sites More sharing options...
ScribbleJ Posted January 20, 2010 Share Posted January 20, 2010 Thats a nifty lisp routine lpseifert. To the OP: Break-at point has always been as it is now (at least since version 10). It was simplified in one command when toolbars were introduced. You can't use a repeat on it. If you do, it will just invoke the regular break command. So in essence break-at can only be invoked from the toolbar each time it is needed. It is the same as using break (at the command line) then picking the first option then typing in the @ symbol for your second selection. Hence the line (command "break" e1 "f" pause "@" ) in the lisp routine posted by lpseifert. I hope this little history lesson helps you to understand the reason behind this quirky command. Quote Link to comment Share on other sites More sharing options...
nukecad Posted January 20, 2010 Share Posted January 20, 2010 Try putting this macro on a button, I use it frequently - *^C^C_break \_f \@ The '*' tells it to repeat- so one click of the button then pick line, pick break point, pick next line, pick break point, .......etc until you press esc. Quote Link to comment Share on other sites More sharing options...
Ramsden Posted January 20, 2010 Author Share Posted January 20, 2010 Thats a nifty lisp routine lpseifert. To the OP: Break-at point has always been as it is now (at least since version 10). It was simplified in one command when toolbars were introduced. You can't use a repeat on it. If you do, it will just invoke the regular break command. So in essence break-at can only be invoked from the toolbar each time it is needed. It is the same as using break (at the command line) then picking the first option then typing in the @ symbol for your second selection. Hence the line (command "break" e1 "f" pause "@" ) in the lisp routine posted by lpseifert. I hope this little history lesson helps you to understand the reason behind this quirky command. Thanks. But i swear I was able to do a repeat when I was using 2008. Maybe I'm remembering wrong or I did something else... Anyways, thank you all for the replies. It looks like I need to do a bit more reading up on buttons/macros some as most of your answers are foreign to me =) I think I can run with what yall have given me though, thanks again =) Quote Link to comment Share on other sites More sharing options...
motoxrcr Posted January 20, 2010 Share Posted January 20, 2010 It is still the same in 2010, one at a time. Quote Link to comment Share on other sites More sharing options...
ricardocaro Posted November 13, 2013 Share Posted November 13, 2013 hi guys could you help me to find acaddoc.lsp file please? I'm using Autocad 2010 version thanks! Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 13, 2013 Share Posted November 13, 2013 (FINDFILE "ACADDOC.LSP") will return nil if it can't be found or will return the path to it if it can. Quote Link to comment Share on other sites More sharing options...
