ssget won't select the objects toching a line, only those that cross it.
(ssget "_F" (list p1 p2) ) didn't select anything
What method is the best for selecting these objects, if I know the endpoints of the line?
I've tried to create a polygon around the line, but I screwed something up in this code, I'm not sure what. It only works if the angle of the line is below 180.
(setq sp-angle (angle p1 p2))
(setq sp1 (polar p2 (+ sp-angle (/ pi 4)) puffer))
(setq sp2 (polar p2 (- sp-angle (/ pi 4)) puffer))
(setq sp3 (polar p1 (- (abs (- pi sp-angle)) (/ pi 4)) puffer))
(setq sp4 (polar p1 (+ (abs (- pi sp-angle)) (/ pi 4)) puffer))
how about using FASTSELECT, in conjunction with FSMODE ?
I've found it, seems a little bit overkill to me, 420 lines of code :?
You could use a fuzz factor .... say 0.001 and calc the point beyond
(polar p1 (angle p1 p2)(+ 0.001 (distance p1 p2)))
Do not forget to do a zoom extend to both points of the fence line
SSGET only SSGET seen on the screen.
SSGET do a SSGET to ALL enty when SSGET "_X"
Don't have any code of mine on hand, but recall a function from an old friend.
The master John F. Uhden.
Here is the link:
http://www.cadlantic.com/Freebies.htm
And see if SSGETENDS.LSP could help, among some other great stuff available there.
That only extends the line, I'd have to create a polygon that encloses the line. Which I tried to do in the first post, but there is a problem with the angles.
Here is the link:
Thanks but that only selects objects near the ends of the line, which is fairly easy to do almost every lsp I created uses something like this. What I need is to select all objects along the line.
can you paste a image etc not sure exactly what your doing I have a crossing lisp used to dimension multiple lines.
This?
(defun GetTouching (ent fuzz / p1 p2 ang pi/2)
 (setq p1 (cdr (assoc 10 (entget ent)))
       p2 (cdr (assoc 11 (entget ent)))
       ang (angle p1 p2) pi/2 (/ pi 2.))
 (ssget "_CP" (list (polar p1 (+ ang pi/2) fuzz)
                    (polar p1 (- ang pi/2) fuzz)
                    (polar p2 (- ang pi/2) fuzz)
                    (polar p2 (+ ang pi/2) fuzz))))
(defun c:test (/ ent)
 (if (and (setq ent (car (entsel "\nSelect Line: ")))
          (eq "LINE" (cdr (assoc 0 (entget ent)))))
   (sssetfirst nil (GetTouching ent 0.001)))
 (princ))
Thanks, I already figured it out, sorry I didn't indicate it.
