KRBeckman Posted February 3, 2010 Posted February 3, 2010 I'm haveing a hard time with this, can someone tell me what I've got wrong: (defun c:bv () (setq viewport_scale (getreal "\nPlease input the viewport scale you would like to try in decimal format:")) (setq dimension_scale (/ 1 viewport_scale)) (setq viewport_scale_str (rtos viewport_scale 2 4)) (setq viewport_zoom_factor (strcat viewport_scale "XP")) (command "dimlfac" dimension_scale) (command "-dimstyle" "save" "SPECIALS - MODEL" "Y") (command "_.mspace") (command "cvport" "2") (command "zoom" "extends") (command "zoom" "scale" viewport_zoom_factor) (command "cvport" "4") (command "zoom" "extends") (command "zoom" "scale" viewport_zoom_factor) (command "cvport" "5") (command "zoom" "extends") (command "zoom" "scale" viewport_zoom_factor) (command "_.pspace") (command "zoom" "window" "-0.5,-0.5" "11,8.5") ) I think it has something to do with combining a real variable with a string variable, so i tried the rtos function, but its still not working. Any ideas? Quote
KRBeckman Posted February 3, 2010 Author Posted February 3, 2010 Nevermind, I forgot to change the variable name in the line where i combine the text streings. Quote
Lee Mac Posted February 3, 2010 Posted February 3, 2010 Try this: (defun c:bv (/ obj ss DimObj Dim) (vl-load-com) (setq Dim "SPECIALS - MODEL") ;; << Dimstyle (setq *doc (cond (*doc) ((vla-get-ActiveDocument (vlax-get-acad-object)))) *defscl (cond (*defscl) (0.5))) (if (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 (getvar 'CTAB)))) (progn (setq *defscl (cond ((getreal (strcat "\nSpecify Viewport Scale (Decimal) <" (rtos *defscl) "> : "))) (*defscl))) (vlax-for obj (setq ss (vla-get-ActiveSelectionSet *doc)) (vla-put-CustomScale obj *defscl)) (vla-delete ss) (setvar 'DIMLFAC (/ 1. *defscl)) (if (not (vl-catch-all-error-p (setq DimObj (vl-catch-all-apply (function vla-item) (list (vla-get-Dimstyles *doc) Dim))))) (vla-CopyFrom DimObj *doc))) (princ "\n** No Viewports Found **")) (princ)) Quote
KRBeckman Posted February 3, 2010 Author Posted February 3, 2010 I had to change it up a bit, because the decimals I was using were rounded to four decimal places and were causing rounding issues, here's the new one, can you make improve this?: (defun c:bv () (setq viewport_scale_fraction (getstring "\nPlease input the viewport scale you would like to try in fraction format (Example: 1-1/2):")) (setq viewport_scale_decimal (if (= viewport_scale_fraction "3/32") (/ (+ 0.0 (/ 3.0 32.0)) 12.0) (if (= viewport_scale_fraction "3/16") (/ (+ 0.0 (/ 3.0 16.0)) 12.0) (if (= viewport_scale_fraction "1/8") (/ (+ 0.0 (/ 1.0 8.0)) 12.0) (if (= viewport_scale_fraction "1/4") (/ (+ 0.0 (/ 1.0 4.0)) 12.0) (if (= viewport_scale_fraction "3/8") (/ (+ 0.0 (/ 3.0 8.0)) 12.0) (if (= viewport_scale_fraction "1/2") (/ (+ 0.0 (/ 1.0 2.0)) 12.0) (if (= viewport_scale_fraction "3/4") (/ (+ 0.0 (/ 3.0 4.0)) 12.0) (if (= viewport_scale_fraction "1") (/ (+ 1.0 (/ 0.0 1.0)) 12.0) (if (= viewport_scale_fraction "1-1/4") (/ (+ 1.0 (/ 1.0 4.0)) 12.0) (if (= viewport_scale_fraction "1-1/2") (/ (+ 1.0 (/ 1.0 2.0)) 12.0) (if (= viewport_scale_fraction "1-3/4") (/ (+ 1.0 (/ 3.0 4.0)) 12.0) (if (= viewport_scale_fraction "2") (/ (+ 2.0 (/ 0.0 1.0)) 12.0) (if (= viewport_scale_fraction "3") (/ (+ 3.0 (/ 0.0 1.0)) 12.0) (if (= viewport_scale_fraction "4") (/ (+ 4.0 (/ 0.0 1.0)) 12.0) (if (= viewport_scale_fraction "16") (/ (+ 16.0 (/ 0.0 1.0)) 12.0) "")))))))))))))))) (setq dimension_scale_decimal (/ 1.0 vewport_scale_decimal)) (setq viewport_scale_str (rtos viewport_scale_decimal 2 ) (setq dimension_scale_str (rtos dimension_scale_decimal 2 14)) (setq viewport_zoom_factor (strcat viewport_scale_str "XP")) (command "-DIMSTYLE" "R" "SPECIALS - PAPER") (setvar "dimlfac" dimension_scale_str) (command "-dimstyle" "save" "SPECIALS - PAPER" "Y") (command "_.mspace") (command "cvport" "2") (command "zoom" "e") (command "zoom" "scale" viewport_zoom_factor) (command "cvport" "4") (command "zoom" "e") (command "zoom" "scale" viewport_zoom_factor) (command "cvport" "5") (command "zoom" "e") (command "zoom" "scale" viewport_zoom_factor) (command "_.pspace") (command "zoom" "window" "-0.5,-0.5" "11,8.5") ) Also, notice I had the wrong Dimension style... It needs to be "Specials - Paper" Thanks for all your help Quote
Lee Mac Posted February 3, 2010 Posted February 3, 2010 Why not look at the distof function? (defun c:bv (/ obj ss scl DimObj Dim) (vl-load-com) (setq Dim "SPECIALS - PAPER") ;; << Dimstyle (setq *doc (cond (*doc) ((vla-get-ActiveDocument (vlax-get-acad-object))))) (if (and (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 (getvar 'CTAB)))) (setq scl (getstring "\nSpecify Viewport Scale: "))) (if (setq scl (distof scl 5)) (progn (vlax-for obj (setq ss (vla-get-ActiveSelectionSet *doc)) (vla-put-CustomScale obj scl)) (vla-delete ss) (setvar 'DIMLFAC (/ 1. scl)) (if (not (vl-catch-all-error-p (setq DimObj (vl-catch-all-apply (function vla-item) (list (vla-get-Dimstyles *doc) Dim))))) (vla-CopyFrom DimObj *doc))) (princ "\n** Invalid Scale Entered **")) (princ "\n** No Viewports Found **")) (princ)) Quote
KRBeckman Posted February 3, 2010 Author Posted February 3, 2010 Cause I'm a rookie and have never heard of that command, let alone how to use it. If you have a better way to achieve what I'm trying to do, I'm all ears. Quote
