derek Posted February 10, 2010 Share Posted February 10, 2010 Im quite new to Map 3D and been trying to play around with transparent hatching over OS maps. I've drawn a polygon. Exported as an SDF. Imported through the task pane. And then when editing in style manager I set up properties to include the transparent fill and for some reason nothing happens? I can edit the line style for the polygon but no fill appears even though I one in the preview? Is there a checkbox somewhere I've not hit? Thanks Quote Link to comment Share on other sites More sharing options...
derek Posted February 15, 2010 Author Share Posted February 15, 2010 Anyone?................ Quote Link to comment Share on other sites More sharing options...
caduser05 Posted June 24, 2010 Share Posted June 24, 2010 Map 3D 2011 will allow transparency of layers and entities. Until you upgrade, you may be able to use some third party add-on. Quote Link to comment Share on other sites More sharing options...
GaryMorin Posted June 30, 2010 Share Posted June 30, 2010 Hi Derek, it should be quite straight forward. What are you seeing, can you see a solid fill or is the region completly transparent? If you are sure the data polygons (and not closed polylines), check that solid fill is selected. Quote Link to comment Share on other sites More sharing options...
