Tom1024 Posted February 15, 2010 Posted February 15, 2010 I have a dynamic block with lot of parameters (Linear, LookUp, and so on) and attributes. If for example Linear Parameter have in the Block Editor set in the Properties Palette Show Properties to Yes, then I can change this value later from Properties Palette. Is possible to change orders of this parameters (Linear, LookUp, and so on) that are shown in the Protertis Palette? (With attributes it is possible - in Block Editor type BATTORDER then in the menu changed Attribute order then save the block and type ATTSYNC.) Quote
