Autosave Deselect
c2designkitchen
Unless you are using pickfirst selection, this might help (after it cancels your selection).
(defun c:Test (/) (sssetfirst nil (ssget "_P")) (princ))
I call it 'Reselect'.
When in selection mode, you can also type "P" and it will select Previous.
Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P
revious/Undo/AUto/SIngle/SUbobject/Object
You can also force AutoCAD to select mode by typing SELECT [enter].
Just in case you like to select your objects before activating command...
The most useful I have found that to be since just recently is that the Select tool will give me the blue squares, so I can easily see overlapping lines. This helps me get the right objects selected and double-check alignment before I engage a command.
The selected lines just become dashed lines when I am selecting something within a command's prompt.
