dwg file included
is there any way to transform the object on the right to the object on the left
by using Autolisp?
like when i load app it will ask me which object, which way to do the offset ( inside or outside ( in this case 1/8 and to the outside ) )
and after the selections it will redraw the object on the right so it looks like the one on the left.
i have 142 objects similar to that one , and it would take me a while to do them.
could anyone help creating the lsp file?
thanks
template.dwg
  • Replies 32
  • Elektryk
    17
  • Lee Mac
    10
  • paulmcz
    2
  • alanjt
    2
by using Autolisp?
and afet [sic] the selections it will redraw the object on the left so it looks like the one on the right.
Which is it?
haaaaaaaaa?
Your original post seems to contradict itself, that is, if I am reading it correctly.
meaning?:huh:
Lee is correct !! read the OP again !!
Which is it?
im sorry........ other way around... :) sorry... I'll fix that...
Its quite a tedious LISP to create - perhaps someone here wants to spend some time on it.
is it possible?
is it possible?
Yes, I would think so, but its not too interesting to create :geek:
so it is hard isnt it?...
No, it seems to just required the creation of a polyline with certain measurements.
still looking.....
As I said, perhaps other members on here want to donate their time to working on a LISP for you.
Here is the deal:
here you have the first half of the program (transforming selected geometry to the object on the left = "outside") and you finish it for the transformation the other way around. When you get stuck, then ask here.
(defun c:tio (/ aa osn)
 (initget "I O")
 (setq	aa  (getkword "\n Select option -> Inside [i], Outside [O]: ")
osn (getvar "osmode")
 (cond	((= aa "I") (i))
((= aa "O") (o))
(t nil)
(defun o (/ ip p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14)
 (setvar "osmode" 4)
 (setq ipt (getpoint "\n Insert new objects: "))
 (setvar "osmode" 0)
 (princ "\n Select objects to erase: ")
 (setq	ss  (ssget)
ip  (polar ipt pi 7.75)
p1  (polar ip 0 1.75)
p2  (polar p1 (* pi 0.5) 6.0)
p3  (polar p1 0 12.0)
p4  (polar ip 0 15.5)
p5  (polar p4 (* pi 0.5) 8.49331856)
p6  (polar p5 (* pi 0.5) 0.5)
p7  (polar p6 pi 0.5)
p8  (polar p6 pi 15.0)
p9  (polar p5 pi 15.5)
p10 (polar ip 0 0.5)		;
p11 (polar p10 (* pi 0.5) 2.25)
p12 (polar p11 (* pi 0.5) 4.0)
p13 (polar p11 0 14.5)
p14 (polar p12 0 14.5)
 (setvar "osmode" 0)
 (command "pline" ip p1 "a" "d" p2 p3 "l" p4 p5 "a" p7	"l" p8 "a" p9
   "l" "c" "")
 (command "circle" p11 0.125)
 (setq e1 (entlast))
 (command "copy" e1 "" "m" p11 p12 p13 p14 "")
 (command "erase" ss "")
 (setvar "osmode" osn)
(defun i ()
 (alert
   "The <INSIDE> option of the program is to be written by Elektryk"
