I need to change the font of MText in a few drawings. I want to belive there is a better way to do it than do double click on them individually and change it. I also can not highlight them all and use the properties menu to change them because 'font' is not an option. Exploding the MText is also not an option.
Anyone know of a lisp or another way to do this?
Font is not a option, but style is a option, just filter all the mtext you want and change their styles to a similar style with diferent font.
Either way, i don't know how to change only the font of a text or mtext, is there a way? (with lisp)
Here is what I am using right now....
(command "-style" "NEWSTYLE" "ROMANS.SHX" "3/32" "1" "0" "N" "N" "N")
;; edit above for your target font, height, width factor, oblique angle..
(defun C:CHGMTEXT ( / ss )
(setq ss (ssget "X" (list (cons 0 "MTEXT"))))
(if ss
(setq C 0)
(repeat (sslength ss)
(setq entx (ssname ss C))
(setq ent (entget entx))
(setq ent (subst (cons 7 "NEWSTYLE")(assoc 7 ent) ent))
(entmod ent)
(setq C (+ C 1))
); repeat
); progn
); if
); function
It does exactly what you are telling me to do, but after it has run the style of all the MText is changed but the font remains the same.
Do you have an idea why the font would not change?
O.o
Is the style OK? with a different font?
It works fine here...
O.o
To my knowlege the style is ok... The lisp does not get stuck or have any errors.
I tried other fonts but get the same resaults... The style changes in all the MText but the font remains the same as it started.
I don't know why it's not working for you. The lisp you post works fine here on my pc.
Indeed, there is a way to create style wiht entmake (just for your knowledge)
(entmake
 (list
   '(0 . "STYLE")
   '(100 . "AcDbSymbolTableRecord")
   '(100 . "AcDbTextStyleTableRecord")
   (cons 2 "NEWSTYLE")
   (cons 3 "ROMANS.SHX")
   '(70 . 0)
   '(40 . 0.0938)
   '(41 . 1.0)
   '(50 . 0.0)
   '(71 . 0)
   '(42 . 0)
   '(4 . "")
i'm curious now... there is a way to change only the font with lisp?
'Font' that is independent of style is encoded within the MText string, not the style.
Dang.... That must be what is going on. i received these drawings from a client that does not have many drafting standards. They must be changing them in each of the MText insertions.
Is there any way to fix the font if this is the case?
I would be very interested if it is possible. Would save me a big headache.
Here is an example of what I mean, a crude example at best.
(defun c:FontChange (/ i ss ent eLst)
 (if (setq i -1 ss (ssget "_:L" '((0 . "MTEXT"))))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (entmod
       (subst
         (cons 1
           (strcat "{\\fCopperplate Gothic Bold|b0|i0|c0|p34;"
                   (cdr (assoc 1 (setq eLst (entget ent)))) "}"))
         (assoc 1 eLst)
         eLst))))
 (princ))
To 'Unformat', see here:
http://www.theswamp.org/index.php?topic=31584.0
Wow... This is nice! This will work fine. I guess they did change it manually within the MText... Thanks Lee
Yes, there is a lot more than just font that can be changed with MText - its hell for programmers.
I have this problem through multiple drawings... Is there a way to use this program in a script or batch somehow?
If it requires to much work it is really not necessary as this program will already save me loads of time.
its hell for draughties too. The embedded font information is one of my pet hates with MTEXT.
Would you like it to make you a pot of tea while we're at it...
I would agree with you there - it seems not to follow the usual properties/methods structure of AutoCAD - why would you find the properties inside the content of the MText...? :?
On R2006 you can quick select all the mtext entries and just change the style on them without issue in the properties window and it updates to the Font for that style.
UNLESS.. the font within the MTEXT has been overridden, either manually, or by pasting information in there that had font formatting on it (ie - not notepad basic text, but wordpad or "rich-text" emails or something).
Mtext allows you to change font in midstream, so you'd have to set-it-up to select the text and spaces in the mtext entry itself.. It's like a rich text entry.
I dunno' how it would store the changes in a single "font" attribute.. It must use multiple somehow, unless it stores something like "THIS font for the first 3 letters, THIS font for the next 4, etc"
I did an MTEXT that used the textstyle font by default, and then selected random portions of it, and changed the fonts in places.. Changing the STYLE changed all the text that was using the default style, but left the customized parts alone.
I'd be concerned making mass changes to MTEXT though.. not without verifying it.. I'd have to know how it would treat fractions and stuff.. it might ignore them, or stack/unstack according to unknown rules.
Yes, the MText uses formatting codes nested within the textstring itself - see my reply in post #10 for an example of what I am talking about :)
ahh.. I didn't understand the coding you provided, and couldn't use the link without a log-in for those forums.
I registered, but it's still pending their authorization. Thanks though, I'll check later, assuming they let me in.. though I'm guessing from your comment here that it's essentially what I said. :)
