I removed this and now it at least loads...
The Polar calculations have issues...
Looks like the c:dtr is looking for "x" and no "x" is being passed to it.
Not sure what you are trying to calculate in order to be of further help.
I was under the impression that it needed both of them I'll try it with just the one and see what happens.
try changing this
(defun c:dtr (x)
      (* pi (/ x 180.0))
to this and see if it works
(defun dtr (x)
      (* pi (/ x 180.0))
This should work:
; BY COLIN MACKENZIE
; DRAWS SPRINKLER HEAD WITH MAX RADIUS
(defun C:head (/ oldsnap oldblipmode ip r1 r2 r3)
 ;define the function
 ;Save System Variables
 (setq oldsnap (getvar "osmode")) ;save current snap settings
 (setq oldblipmode (getvar "blipmode")) ; save current blipmode settings
 ;switch OFF system variables
 (setvar "osmode" 2)
 (setvar "blipmode" 0)
 ;Get User Input
 (setq ip (getpoint ":\nEnter Insertion Point : "))
 ;Polar Calculations
 (setq r1 (polar ip (dtr 180.0) 59   ))
 (setq r2 (polar ip (dtr 180.0) 119  ))
 (setq r3 (polar ip (dtr 180.0) 3200 ))
 ; Command Function
 (command "circle" ip r1
      "circle" ip r2
      "circle" ip r3
 ; Reset System Variables
   (setvar "osmode" oldsnap)
   (setvar "blipmode" oldblipmode)
 ; Finish Cleanly
) ;End Function
 ; Converts Degrees to Radians
(defun dtr (x) (* pi (/ x 180.0)))
A few notes on where you went wrong:
  • You suppressed the return of the dtr function using princ, so the value would not be returned when used in the main function.
  • DTR was defined as a function to be invoked at the command line, not a sub-function.
  • You enclosed your arguments for the polar function within brackets, which would indicate they are functions in themselves.
  • You should always localise your variables.
  • You don't actually need (vl-load-com), as you are not using any Visual LISP functions.
Lee
Right cheers for the tips Lee.
But now it says ;error: bad argument type : numberp
Now I'm really confused. What's numberp?
Sorry missed a parenthesis, it works fine, thanks loads Lee!
FYI,
stringp -- argument should be a string (but isn't)
numberp -- argument should be a number
fixnump -- argument should be an integer [eg. try (itoa 1.2) ]
etc etc
