batman67 Posted April 4, 2010 Posted April 4, 2010 I have 200 plans drawn by the command of trace. I want to convert the trace line to simple line. I have made a macro to convert the trace line to polyline. But the result is that it is not a staright line. Anyone can help me to solve this problem. Thanks Quote
ReMark Posted April 4, 2010 Posted April 4, 2010 Why did you convert to a polyline then instead of an ordinary line? Quote
BearDyugin Posted April 4, 2010 Posted April 4, 2010 Try this code (DEFUN C:TEST (/ SS I TEMP) (SETQ SS (SSGET '((0 . "TRACE"))) I -1 ) (REPEAT (SSLENGTH SS) (SETQ TEMP (ENTGET (SSNAME SS (SETQ I (1+ I)))) ) (ENTMAKE (LIST '(0 . "LINE") (ASSOC 8 TEMP) (IF (ASSOC 62 TEMP) (ASSOC 62 TEMP) '(62 . 256) ) (CONS 10 (MAPCAR '(LAMBDA (X Y) (/ (+ X Y) 2)) (CDR (ASSOC 10 TEMP)) (CDR (ASSOC 11 TEMP)) ) ) (CONS 11 (MAPCAR '(LAMBDA (X Y) (/ (+ X Y) 2)) (CDR (ASSOC 12 TEMP)) (CDR (ASSOC 13 TEMP)) ) ) (ASSOC 210 TEMP) ) ) (ENTDEL (SSNAME SS I)) ) ) Quote
batman67 Posted April 5, 2010 Author Posted April 5, 2010 Sub CommandButton1_Click() Dim entry As AcadObject Dim MyLine As AcadLine Dim MyTrace As AcadTrace Dim MyPoly As AcadPolyline Dim MyThick As Double Dim MyLineType As ACAD_LTYPE Dim MyPoints(0 To 5) As Double Dim CordPoints If TextBox1.Text > vbNullString Then MyThick = TextBox1.Text Else MyThick = 0.003 ' End If For Each entry In ThisDrawing.ModelSpace 'MsgBox entry.ObjectName If TypeOf entry Is AcadLine Then Set MyLine = entry MyLineType = MyLine.Linetype MyPoints(0) = MyLine.EndPoint(0) MyPoints(1) = MyLine.EndPoint(1) MyPoints(2) = 0 MyPoints(3) = MyLine.StartPoint(0) MyPoints(4) = MyLine.StartPoint(1) MyPoints(5) = 0 Set MyPoly = ThisDrawing.ModelSpace.AddPolyline(MyPoints) MyPoly.ConstantWidth = MyThick MyPoly.Linetype = MyLineType MyPoly.Update MyLine.Delete 'Set MyLine = Nothing 'Set MyPoly = Nothing ElseIf TypeOf entry Is AcadTrace Then Set MyTrace = entry CordPoints = MyTrace.Coordinate(0) MyPoints(0) = CordPoints(0) MyPoints(1) = CordPoints(1) MyPoints(2) = CordPoints(2) CordPoints = MyTrace.Coordinate(3) MyPoints(3) = CordPoints(0) MyPoints(4) = CordPoints(1) MyPoints(5) = CordPoints(2) Set MyPoly = ThisDrawing.ModelSpace.AddPolyline(MyPoints) MyPoly.ConstantWidth = MyThick MyPoly.Update MyTrace.Delete 'Set MyTrace = Nothing 'Set MyPoly = Nothing End If Next entry Set entry = Nothing Set MyTrace = Nothing Set MyPoly = Nothing Set MyLine = Nothing Unload Me End Sub Quote
batman67 Posted April 5, 2010 Author Posted April 5, 2010 I am sorry. I do not know how to use the code. Can you give me instruction. Thanks Quote
Cad64 Posted April 5, 2010 Posted April 5, 2010 How to use an AutoLisp Routine: http://www.cadtutor.net/faq/questions/28/How+do+I+use+an+AutoLISP+routine%3F Quote
