evanm33 Posted April 9, 2010 Share Posted April 9, 2010 Good Morning Everyone, I have the same problem every morning when i try to start up AutoCAD Mechanical 2010. It will start the application and show the mechanical background just like normal but then when it tries to open the default template it stops responding. The toolbars don't show up, the comand line doesn't show up, and the loading bar doesn't show up. Also once it gets to this stage the icons on the title bar and taskbar switch to the regular autocad 2010 icons as opposed to the mechanical icons. I restart my computer and its random whether it will act like this again or start up correctly. As stated above, I'm running AutoCAD Mechanical 2010. My computer is a three week old Dell with intel zeon and windows 7 64-bit. It worked fine for about a week and now this. Has anyone had this happen to them or have an idea of what might be causing the problem? Me and the IT crew are completely stumped. Any help would be greatly appreciated. Thanks, Evan Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 9, 2010 Share Posted April 9, 2010 Sounds like something got corrupted. Have you tried the AutoCAD REPAIR option? Quote Link to comment Share on other sites More sharing options...
Car5858 Posted April 9, 2010 Share Posted April 9, 2010 Customization file loaded successfully. Customization Group: AMPP Customization file loaded successfully. Customization Group: AMACAD Customization file loaded successfully. Customization Group: AUTODESKSEEK Loading Mechanical modules..... Loading Modeler DLLs. Loader application completed Regenerating model. AutoCAD menu utilities loaded. Command: COMMANDLINE The above is what mine shows as it is started up. I had this problem a couple of weeks ago. After a repair of the installation every thing seems to be working fine. I did the installation in its own directory, not in the program files. I think this is a Win7 issue. I belive that the file association was lost some how. Quote Link to comment Share on other sites More sharing options...
evanm33 Posted April 9, 2010 Author Share Posted April 9, 2010 I'll try the repair first and if that doesn't work I'll reinstall to it own directory. Thanks for your help guys. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 9, 2010 Share Posted April 9, 2010 Be sure to uninstall per AutoDesk directions. Quote Link to comment Share on other sites More sharing options...
evanm33 Posted April 12, 2010 Author Share Posted April 12, 2010 It started up first try today, so the repair seems to have works. Thanks again guys for your suggestions. Quote Link to comment Share on other sites More sharing options...
