firas87 Posted April 11, 2010 Share Posted April 11, 2010 hi, im kind of new to autocad. i have my polyline in model space in 1:1 scale and need to plot it on an A4 sheet with a scale of 1:2000 H and 1:200 V, i.e i will need abt 7 sheets A4, so how it all goes, in addition i need dimensions not to change upon changing scale.10x 4 any help:). Quote Link to comment Share on other sites More sharing options...
alanjt Posted April 11, 2010 Share Posted April 11, 2010 You can set a viewport (in paperspace) to plot to any scale. Your dimension will not change since it's tied to the selected PLine. Quote Link to comment Share on other sites More sharing options...
nukecad Posted April 11, 2010 Share Posted April 11, 2010 You can't have a different H and V plot scale, AutoCAD wont do that. If you realy need to have different H & V scales then you will have to scale/stretch the profile in modelspace before plotting. Why do you need different H & V scales:?: Quote Link to comment Share on other sites More sharing options...
firas87 Posted April 11, 2010 Author Share Posted April 11, 2010 well nukecad, my project is a profile section of a highway it is 2920m long n delta y is abt 35 m. I'm asked to plot the profile on an A4 paper using scale: H 1:2000 and V 1:200, so if you calculate you'll need abt 7 papers A4, and im stuck to this issue. Quote Link to comment Share on other sites More sharing options...
BearDyugin Posted April 11, 2010 Share Posted April 11, 2010 Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 11, 2010 Share Posted April 11, 2010 Draw the grid with the spacing the same in both the horizontal and vertical directions then save it as a block. Insert it with a different scale factor for X and Y. Quote Link to comment Share on other sites More sharing options...
AJSmith Posted April 12, 2010 Share Posted April 12, 2010 when i do long road sections i do as ReMark said save the profile as a block and adjust the x y scales in the properties Quote Link to comment Share on other sites More sharing options...
