rookie37 Posted April 18, 2010 Share Posted April 18, 2010 I need to insert a block multiple times by reading the x and y coordinates from a spreadsheet. the spreadsheet will be c:\my documents\survey\abc engineering\test.xls sheet; green street column b7 - aa7 = x coordinate column b8 - aa8 = y coordinate insert block survey peg 1.dwg This may be too much for lisp. However if you write it in VB, I'll probably hit you with many questions as I don't know how to load, run, or set a path for VB. Quote Link to comment Share on other sites More sharing options...
stevesfr Posted April 19, 2010 Share Posted April 19, 2010 I need to insert a block multiple times by reading the x and y coordinates from a spreadsheet. the spreadsheet will be c:\my documents\survey\abc engineering\test.xls sheet; green street column b7 - aa7 = x coordinate column b8 - aa8 = y coordinate insert block survey peg 1.dwg This may be too much for lisp. However if you write it in VB, I'll probably hit you with many questions as I don't know how to load, run, or set a path for VB. This might help... http://www.cadtutor.net/forum/showthread.php?t=42954&highlight=ptmanager Quote Link to comment Share on other sites More sharing options...
