Sparky Posted April 19, 2010 Share Posted April 19, 2010 Morning, I'm trying to create a dynamic block for various rebar sizes. I started with a circle and applied a linear parameter with a stretch action so as to stretch the rebar equally in all four dirctions so I could maintain the center point. The circle didn't work so I tried using (2) polyline arcs and I still had no luck. I have attached the file that I started with. I would like to have this set up so I could have a #3 (3/8" DIA.) rebar, #4 (1/2" DIA.).... Which parameter do I need? Thanks! Rebar -4-19-10.dwg Quote Link to comment Share on other sites More sharing options...
dbroada Posted April 19, 2010 Share Posted April 19, 2010 I would try using a linear parameter (distance or point) with a list of sizes and add a scale action to the circle. Quote Link to comment Share on other sites More sharing options...
Sparky Posted April 19, 2010 Author Share Posted April 19, 2010 dbroad, You da man. I applied a linear parameter from the center to the right quadrant and a linear parameter center to the left quadrant, applied a scale action to each parameter and specified the raduis in the look up parameter and it works great. Thanks for your help. Have a blessed day! Quote Link to comment Share on other sites More sharing options...
