I have this lisp by kpblc and it takes everything in a block and changes its properties to by layer. Works great, except for attributes then you have to go back and attsync each block individually, is there a way with lisp to attsync all blocks within a dwg at once, and either add it to the lisp below or just a seperate lisp that does this or a command im totally missing. The other problem is Mtext, if mtext color is selected within the mtext editor dialog box is there a way to change it back to by layer without going into each mtext individually, also would be great added into this lisp but a seperate lisp you have that does the same thing would work too. I know a little about lisp so i can add to mine so it calls other lisps at the end to bring these in.
Author kpblc
changes all blocks inserted in a dwg from by block/color to by layer.
(defun c:norm (/ *error* adoc lst_layer func_restore-layers)
 (defun *error* (msg)
   (func_restore-layers)
   (vla-endundomark adoc)
   (princ msg)
   ) ;_ end of defun
 (defun func_restore-layers ()
   (foreach item lst_layer
     (vla-put-lock (car item) (cdr (assoc "lock" (cdr item))))
     (vl-catch-all-apply
       '(lambda ()
          (vla-put-freeze (car item) (cdr (assoc "freeze" (cdr item))))
          ) ;_ end of lambda
       ) ;_ end of vl-catch-all-apply
     ) ;_ end of foreach
   ) ;_ end of defun
 (vl-load-com)
 (vla-startundomark
   (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
   ) ;_ end of vla-startundomark
 (vlax-for item (vla-get-layers adoc)
   (setq lst_layer (cons (list item
                               (cons "lock" (vla-get-lock item))
                               (cons "freeze" (vla-get-freeze item))
                               ) ;_ end of list
                         lst_layer
                         ) ;_ end of cons
         ) ;_ end of setq
   (vla-put-lock item :vlax-false)
   (vl-catch-all-apply '(lambda () (vla-put-freeze item :vlax-false)))
   ) ;_ end of vlax-for
 (vlax-for blk (vla-get-blocks adoc)
   (if (and (equal (vla-get-islayout blk) :vlax-false)
            (equal (vla-get-isxref blk) :vlax-false)
            ) ;_ end of and
       (vlax-for subent blk
          ;(vla-put-layer subent "0");edit-> removed force to layer 0
         (vla-put-color subent 256)
         (vla-put-lineweight subent aclnwtbyblock)
         (vla-put-linetype subent "byblock")
       ) ;_ end of progn
     ) ;_ end of if
(command "_regenall")
 ) ;_ end of defun
battman and the sync button work a little fast then attsync each individual block but still looking for some way to do it all at once
so simple, thanks lee mac. Any ideas on the mtext problem?
Give this a look.
thanks alan that works like a charm
Joe and Steve did a great job with it.
