muthu123 Posted May 5, 2010 Share Posted May 5, 2010 Dear friends, We need a dialog/form to select multiple drawings from multiple folder with the buttons add drawings,delete drawings. It should return all the drawing list with its path to process some task. Yours, Muthu. Quote Link to comment Share on other sites More sharing options...
Tiger Posted May 5, 2010 Share Posted May 5, 2010 For drawing management, which I assume is where you are heading with this even if the question is pretty vague - I would explore Autodesk Vault. I haven't used it myself, but from what I have heard it is good. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 5, 2010 Share Posted May 5, 2010 Windows Explorer Quote Link to comment Share on other sites More sharing options...
muthu123 Posted May 5, 2010 Author Share Posted May 5, 2010 For drawing management, which I assume is where you are heading with this even if the question is pretty vague - I would explore Autodesk Vault. I haven't used it myself, but from what I have heard it is good. Thank you lee. Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 5, 2010 Share Posted May 5, 2010 The Batch engine in my signature utilizes one. I've stripped it out for your convenience. Just update the "root" and "rotLst" variables in the function to accommodate your needs, as well as the "diaID1" variable to locate the accompanied .dcl file. You can call the function as so: (dwgdia nil) I hope it works for you. dwgdia.LSP DIALOG_FOLDERS.dcl Quote Link to comment Share on other sites More sharing options...
muthu123 Posted May 5, 2010 Author Share Posted May 5, 2010 Windows Explorer I can't understand what you mean "windows explorer" Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 5, 2010 Share Posted May 5, 2010 http://en.wikipedia.org/wiki/Windows_Explorer Quote Link to comment Share on other sites More sharing options...
muthu123 Posted May 5, 2010 Author Share Posted May 5, 2010 The Batch engine in my signature utilizes one. I've stripped it out for your convenience. Just update the "root" and "rotLst" variables in the function to accommodate your needs, as well as the "diaID1" variable to locate the accompanied .dcl file. You can call the function as so: (dwgdia nil) I hope it works for you. There is no function defined in your lisp. "FB-STRING-DELIM" Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 5, 2010 Share Posted May 5, 2010 There is no function defined in your lisp."FB-STRING-DELIM" Gah! Rookie mistake, my bad. Add this to the .lsp file and reload it. Sorry! (defun fb-string-delim(str del / runLst runStr newLst); (setq runLst (vl-string->list str) runStr "" newLst nil) (foreach forVar runLst (if (/= (ascii del) forVar) (setq runStr (strcat runStr (chr forVar))) (setq newLst (append newLst (list runStr)) runStr "")) ) (setq newLst (append newLst (list runStr))) ); Parses a string into a list of strings given a certain delimiter Funny thing was, when I was extracting the function from my batch engine, I had problems with this part. You don't need it, it was just a convenient way for me to create a list of all the drives we use at work without typing them all individually. I wanted to be weird. Just as long as "rotLst" contains a list of directories, you're good. Quote Link to comment Share on other sites More sharing options...
muthu123 Posted May 5, 2010 Author Share Posted May 5, 2010 Gah! Rookie mistake, my bad. Add this to the .lsp file and reload it. Sorry! (defun fb-string-delim(str del / runLst runStr newLst); (setq runLst (vl-string->list str) runStr "" newLst nil) (foreach forVar runLst (if (/= (ascii del) forVar) (setq runStr (strcat runStr (chr forVar))) (setq newLst (append newLst (list runStr)) runStr "")) ) (setq newLst (append newLst (list runStr))) ); Parses a string into a list of strings given a certain delimiter Funny thing was, when I was extracting the function from my batch engine, I had problems with this part. You don't need it, it was just a convenient way for me to create a list of all the drives we use at work without typing them all individually. I wanted to be weird. Just as long as "rotLst" contains a list of directories, you're good. Please send the following function also. error: no function definition: FB-DIRFIX Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 5, 2010 Share Posted May 5, 2010 *headdesk* See, I haven't looked into the code for this in months, so I forget what's supposed to be there.. Add these three, and -hopefully- that should do it... (defun fb-dirFix(listy / ) (vl-remove-if '(lambda (x) (or (= x ".") (= x ".."))) listy) ); Get rid of the root and parent options in a passed directory (defun fb-dirLstFix(dir / subSpa) (setq subSpa "") (repeat (length (vl-remove-if-not '(lambda (x) (= x 47)) (vl-string->list dir))) (setq subSpa (strcat subSpa " "))) (strcat subSpa (vl-filename-base dir) (if (vl-filename-extension dir) (vl-filename-extension dir) "")) ); Modify a directory to visually represent its hierarchy position (defun fb-filLstFix(dir / newDir dirLst) (setq newDir "" dirLst (fb-string-delim dir "/")) (foreach forVar (reverse (cdr (reverse dirLst))) (if (> (strlen forVar) 5) (setq newDir (strcat newDir (substr forVar 1 5) " ... /")) (setq newDir (strcat newDir forVar "/")) ) ) (setq newDir (strcat newDir (last dirLst))) ); Modify a directory to condense its length Quote Link to comment Share on other sites More sharing options...
muthu123 Posted May 5, 2010 Author Share Posted May 5, 2010 *headdesk* See, I haven't looked into the code for this in months, so I forget what's supposed to be there.. Add these three, and -hopefully- that should do it... (defun fb-dirFix(listy / ) (vl-remove-if '(lambda (x) (or (= x ".") (= x ".."))) listy) ); Get rid of the root and parent options in a passed directory (defun fb-dirLstFix(dir / subSpa) (setq subSpa "") (repeat (length (vl-remove-if-not '(lambda (x) (= x 47)) (vl-string->list dir))) (setq subSpa (strcat subSpa " "))) (strcat subSpa (vl-filename-base dir) (if (vl-filename-extension dir) (vl-filename-extension dir) "")) ); Modify a directory to visually represent its hierarchy position (defun fb-filLstFix(dir / newDir dirLst) (setq newDir "" dirLst (fb-string-delim dir "/")) (foreach forVar (reverse (cdr (reverse dirLst))) (if (> (strlen forVar) 5) (setq newDir (strcat newDir (substr forVar 1 5) " ... /")) (setq newDir (strcat newDir forVar "/")) ) ) (setq newDir (strcat newDir (last dirLst))) ); Modify a directory to condense its length Thank you so much. Now it is working fine. Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 5, 2010 Share Posted May 5, 2010 Happy to help! Especially since the first time I posted it, I got nothing but complaints about the layout. Quote Link to comment Share on other sites More sharing options...
