Legallytired Posted May 5, 2010 Share Posted May 5, 2010 I'm quite a beginner in AutoCAD and here are the two problems I'm having: #1 : I'm modelling some basic stuff in 3d and for some reason the dimensions of the objects I'm trying to create are not appearing at all. As in the modifiable blue boxes you can navigate using TAB to adjust the dimensions of your object when you are drawing it but before it is drawn. #2 : This one might be more complicated : I was completing a drawing and got some Heidi related errors. Now my object sheet is all grey and I cannot see anything I drew. The XYZ thing is still there however. I'm not aware of anything I could've done that would've erased the solids I was working on.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 5, 2010 Share Posted May 5, 2010 #2 - Try switching to a 2D wireframe visual style and see if there are any objects present. Quote Link to comment Share on other sites More sharing options...
Legallytired Posted May 5, 2010 Author Share Posted May 5, 2010 Seems like it's all gone. Weird stuff going on there. Any idea how to bring back the dimensions? Seems easier for me to create solids when I can write down my lenghts directly on the layout sheet. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 5, 2010 Share Posted May 5, 2010 Did you do a zoom > extents too? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 5, 2010 Share Posted May 5, 2010 Are you actually dimensioning the 3D object itself? Quote Link to comment Share on other sites More sharing options...
Legallytired Posted May 5, 2010 Author Share Posted May 5, 2010 Did do the Zoom extents - Seems like everything vanished. Yes, I'm using really basic shapes. Say, when I'm creating a box I can write the length/width directly on the layout sheet then press enter. Then I can add the height on the sheet, press enter and my box is drawn. I'm also using a french version of the program and it is really driving me insane. Thanks a lot for the help. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 5, 2010 Share Posted May 5, 2010 You're drawing in model space or in paper space (via a layout)? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 5, 2010 Share Posted May 5, 2010 Sound like you might have turned off Dynamic Input. Quote Link to comment Share on other sites More sharing options...
