TigWelder Posted May 12, 2010 Share Posted May 12, 2010 Hi everyone, long time lurker, 1st time poster here. I'm trying to extrude a 3D sketch and also make it a surface so it will be a curved Cap for a Tank. Whenever I try to extrude the 3D sketch it asks for direction to be specified and when I try a direction it gives me geometry errors, so it doesn't work. I also tried the Insert/Surface/Fill feature and it doesn't fill the surface flat (like I need it to do). Does anyone know how to do this? I feel like it's a simple step or procedure I'm missing... 3D Sketch of the end cap Tank that needs the above-outlined 3D cap to seal it Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 12, 2010 Share Posted May 12, 2010 I also tried the Insert/Surface/Fill feature and it doesn't fill the surface flat (like I need it to do). Can you attach the file here? Looks like you should be able to do a boundary fill and Thicken to get your cap. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 12, 2010 Share Posted May 12, 2010 Hey Tig. Well the short answer is you cant extrude a 3d sketch. It needs to be 2d. Now there are a few ways you can make that shape though. Using your 3d sketch you can do a Filled Surface then Thicken it. You will need some guides or you can use a combination of Boundary surfaces. Knit them together then thicken. You can extrude the profile of that in 2d, do a full round fillet. The first two pics show the 2d profile extruded, then a full round fillet added. The next 6 or so show the surface method(one of many) using a 3d sketch. If you go this route when using boundary surface, right click and use the Selection Manager to pick parts of your 3d sketch. I show you the order in which i filled in. Each "panel" is a new boundary surface. I could have done the first 3 together but for this purpose i felt it was easier to show you every piece by itself. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 12, 2010 Share Posted May 12, 2010 ps, look like your building an intake manifold:) Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 12, 2010 Share Posted May 12, 2010 Matt - does it look like to you that he did a Delete Face on one of the faces? TigWelder do you have a folder at the top of the browser named Surface Bodies? Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 12, 2010 Share Posted May 12, 2010 Matt - does it look like to you that he did a Delete Face on one of the faces? TigWelder do you have a folder at the top of the browser named Surface Bodies? either that or he is building the whole thing with surfaces. Quote Link to comment Share on other sites More sharing options...
TigWelder Posted May 13, 2010 Author Share Posted May 13, 2010 I tried to attach the part file, but this forum wouldn't allow that solidworks part file name extension. I changed the transparency of the plenum just to make it easier for me to visualize design changes, hence the "missing wall." Thank you for all your help, I will try the suggested method (& report results), and yes it is an intake manifold shift1313 . Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 13, 2010 Share Posted May 13, 2010 i just finished an intake for my turbo bike that has a similar shape. im not happy with the welds but it was done in less than ideal conditions:) To upload your files here just create a zip file. It will let you attach that. this is what i started with. Quote Link to comment Share on other sites More sharing options...
chetan0503 Posted July 8, 2011 Share Posted July 8, 2011 hi chetan here i hv same problem in extrusion in 3d sketch same problem with directions Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 8, 2011 Share Posted July 8, 2011 hi chetan here i hv same problem in extrusion in 3d sketch same problem with directions Zip and attach the file here (roll op the feature tree first). Quote Link to comment Share on other sites More sharing options...
kush_ciis Posted March 27, 2012 Share Posted March 27, 2012 I was making a crown similar to Burger King's crown and got stuck midway. I do not have much experience with 3D sketches, please help! PS- please see attached jpeg Quote Link to comment Share on other sites More sharing options...
