SadisticIron Posted May 12, 2010 Share Posted May 12, 2010 I have only dabbled into 3d as of lately. I am working with v2009 and I can not for some reason get a horizontal cylinder to represent the center axle section. All I can get is vertical visuals right now. Thank you Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 12, 2010 Share Posted May 12, 2010 UCS Enter F1 Quote Link to comment Share on other sites More sharing options...
SadisticIron Posted May 12, 2010 Author Share Posted May 12, 2010 Thank you, I didn't even know were to start and this will be it. Quote Link to comment Share on other sites More sharing options...
SadisticIron Posted May 12, 2010 Author Share Posted May 12, 2010 JD thank you. I was able to create my axle and rotate it to where it looks as if I am behind it. Next question would be if I want to build off of this cylinder will I go back into UCS and go back and forth from there or do you recommend layers to me. I am trying to mock up a rear suspension setup as I am in the mini truckn fabrication industry. Thank you for pointing me in the right directions. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 12, 2010 Share Posted May 12, 2010 Most of the time I use DUCS so that I don't have to fool with UCS. I make extensive use of layers. You might go through the tutorials in my signature. Quote Link to comment Share on other sites More sharing options...
