chief Posted May 14, 2010 Share Posted May 14, 2010 Is there any way I can lock my layers so that no new layers will be added even if the drawing I import has new layers? I have a client who only wants the same 84 layers used in each drawing for a program at his end. However some of the drawing I import have new/different layers which are then added to the layer set. Regards Luke Quote Link to comment Share on other sites More sharing options...
alanjt Posted May 14, 2010 Share Posted May 14, 2010 No, you can't stop a layer from being created when inserting objects from another drawing. All you can do is translate the translate the unwanted layers to wanted ones. Quote Link to comment Share on other sites More sharing options...
chief Posted May 17, 2010 Author Share Posted May 17, 2010 Thanks for your help. I'm trying to delete some of the unwanted layers, however even though I'm removing all the data on a particular layer and then trying to delete it I'm still getting an error message saying I cant do it, any ideas? Quote Link to comment Share on other sites More sharing options...
alanjt Posted May 18, 2010 Share Posted May 18, 2010 Probably have a nested object on the layer. Look into: LayTrans, LayMrg, LayDel Quote Link to comment Share on other sites More sharing options...
NBC Posted May 18, 2010 Share Posted May 18, 2010 Probably have a nested object on the layer. Look into: LayTrans, LayMrg, LayDel Can I also add LAYWALK Quote Link to comment Share on other sites More sharing options...
