NikOvstaas Posted May 17, 2010 Share Posted May 17, 2010 im trying to change the line weight of an existing line on my colleagues drawing, and although it says its the desired weight in the properties, it still looks the exact same... Quote Link to comment Share on other sites More sharing options...
nukecad Posted May 17, 2010 Share Posted May 17, 2010 Check BYLAYER , BYBLOCK. When you say that 'it looks the exact same' is this on screen or on a print? If its just on screen then check that you have your setup to display lineweights. (Sorry, not sure where it is in 2010 but there used to be a tab at the bottom of the screen in older versions). Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2010 Share Posted May 17, 2010 There is a Show / Hide Lineweight button in the Tray at the very bottom of your screen. In older version you might see the button has the letters LWT on it. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted May 18, 2010 Share Posted May 18, 2010 Is it a polyline with a global width set to it? Quote Link to comment Share on other sites More sharing options...
NikOvstaas Posted May 18, 2010 Author Share Posted May 18, 2010 thanks, problem solved! Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted May 18, 2010 Share Posted May 18, 2010 What was the solution that you used? Quote Link to comment Share on other sites More sharing options...
NikOvstaas Posted May 20, 2010 Author Share Posted May 20, 2010 I didnt have my setup to display lineweights. Just had to tweak the settings a bit. thanks again. Quote Link to comment Share on other sites More sharing options...
