Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    Default How To Dimension An Elipse
    I'm trying to dimension the diameter of the elipse in the attached dwg.
    I do dimension, diameter and it asks to select the arc or circle. I select the elipse and it tells me it's not an circle or an arc. I know this, but see no other option under dimension for elipse.
    ISO.dwg
    Super Member mdbdesign's Avatar
    mdbdesign's Computer Details
    XP PRO
    Homemade
    GIGABYTE G31M-ES2L
    INTEL CORE 2-QUAD-Q6600@2.4GHz
    4 GB
    NVIDIA GeForce 9800 gt 1gb
    WESTERN DIGITAL 500GB
    2 - 21" COMPACQ
    Mechanical
    mdbdesign's Discipline Details
    Designing Engineer in Engineering Department
    Mechanical
    Pressure tanks Oil processing & storage equip. Steel mill equip. Telecom towers & equip. Wind turbine towers Power plant structures etc.
    AutoCAD 2012
    Jan 2007
    Courtice, Ontario, Canada
    749
    Snap to quadrant your dimension line.
    I think you can dimension only long and short axis and lengthen of ellipse.
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    Quote Originally Posted by mdbdesign View Post
    I have my osnap/quadrant set to on, but it doesn't snap to the quadrant of the elipse. You lost me on the long and short axis thing.
    BTW, I'm using 2009LT.
    Super Member Ryder76's Avatar
    Ryder76's Computer Details
    Windows 7
    Dell T7500
    See details...
    Ryder76's Discipline Details
    Electrical Designer - Oil & Gas
    See details below.
    Subsea Solutions
    AutoCAD 2010
    May 2009
    Houston, Texas
    570
    Set your osnap settings to quadrant then dimension as shown.
    "Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
  5. #5
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    Quote Originally Posted by Ryder76 View Post
    Attachment 20420
    Could you look at the elipse in the drawing I attached. I got the snap/quadrant to work, but the elipse is in isometric. It snaps to a quadrant, but not right for a dimension as you have shown above.
    Also, what type of dimension should I use? Aligned?
  6. #6
    XP PRO
    Homemade
    GIGABYTE G31M-ES2L
    4 GB
    2 - 21" COMPACQ
    Mechanical
    Mechanical
    AutoCAD 2012
    Jan 2007
    749
    Ok I did not open your dwg.
    Draw temp lines from midpoint of outside face edges across ellipse (like ellipse center line) and dimension between intersection of ellipse and lines.
  7. #7
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    Sorry, but I'm confused with this. Not sure what you mean by midpoint of outside face.
    I will have to continue this tomorrow, as I must leave work now.
    I appreciate your input.
  8. #8
    Super Member ScribbleJ's Avatar
    ScribbleJ's Computer Details
    Windows 7
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @ 2.8GHz 2800 Mhz
    12 gig
    Nvidia Quadro 600
    237 GB
    Main: Dell 2408 Aux: Dell 1703FP
    Civil
    ScribbleJ's Discipline Details
    Civil Design Tech for Water / Waste Water Industry.
    Civil
    Roadway designs, water and waste-water treatment systems and water distribution systems.
    Civil 3D 2011
    Dec 2008
    Rancho Cordova, CA
    539
    It appears to me that your attempting to dimension a circle in an isometric drawing. If you dimension it from that view the measurement will be incorrect. You need to project it to a front or top view in order to get it correct.
    Edit:
    On second glance my comment about the dimensions apply to your others as well. Those dimensions are going to be incorrect because of them being longer or shorter than what they actually would be in the front, top or right side views.
    Calvin
    Soli Deo Gloria
  9. #9
    XP PRO
    Homemade
    GIGABYTE G31M-ES2L
    4 GB
    2 - 21" COMPACQ
    Mechanical
    Mechanical
    AutoCAD 2012
    Jan 2007
    749
    Quote Originally Posted by ScribbleJ View Post
    Edit:
    On second glance my comment about the dimensions apply to your others as well. Those dimension are going to be incorrect because of them being longer or shorter than what they actually would be in the front, top or right side views.
    Just answering question of dimension of ellipse. Of course it is isometric view of circle.
  10. #10
    Senior Member CJJ's Avatar
    CJJ's Computer Details
    Windows XP
    Old, Slow, Full of porn.
    Civil 3D 2009
    Nov 2009
    North Carolina
    137
    I think the commonly accepted way to do this would be an auxiliary view, where your view is perpendicular to the face with the circle, so you're seeing the feature in question in as a circle, and not an ellipse.
    If that's not an option, you might want to fake it. An ellipse doesn't really want to be dimensioned that way because it doesn't have a standard radius or diameter. You might want to get creative with a LEADER/MLEADER to make it look like your diameter dimensions, and manually type in the desired dimension.
  1. Elipse to polyline?
    By Rob-GB in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Mar 2009, 08:17 am
  2. Replies: 56
    Last Post: 21st Feb 2009, 04:14 am
  3. how do I close an elipse?
    By michaeloureiro in forum AutoCAD Beginners' Area
    Last Post: 9th Dec 2008, 10:57 am
  4. tangent lines to iso elipse
    By m!ni in forum AutoCAD Beginners' Area
    Last Post: 18th Dec 2007, 07:15 pm
  5. Elipse to Polyline
    By daiharv in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Feb 2006, 10:01 pm
