happyunited Posted June 2, 2010 Posted June 2, 2010 I have loads of closed polylines and they have all got a different area. There are hundreds. In the quick select box how would I specify to say select all polylines between a certain area say 100m2 to 500m2? I know to select polylines then area the equal to but what do I put in the box? Thanks Quote
ReMark Posted June 2, 2010 Posted June 2, 2010 Wouldn't you need "greater than" X and "less than" Y? In other words: a range. Quote
Lee Mac Posted June 2, 2010 Posted June 2, 2010 Quick one: (defun c:qs ( / ss ) ;; © Lee Mac ~ 02.06.10 (if (setq ss (ssget "_X" '((0 . "LWPOLYLINE")))) ( (lambda ( i / e area ) (while (setq e (ssname ss (setq i (1+ i)))) (setq area (vlax-curve-getArea e)) (or (< 100. area 500.) (ssdel e ss)) ) ) -1 ) ) (sssetfirst nil ss) (princ) ) Quote
happyunited Posted June 3, 2010 Author Posted June 3, 2010 Quick one: (defun c:qs ( / ss ) ;; © Lee Mac ~ 02.06.10 (if (setq ss (ssget "_X" '((0 . "LWPOLYLINE")))) ( (lambda ( i / e area ) (while (setq e (ssname ss (setq i (1+ i)))) (setq area (vlax-curve-getArea e)) (or (< 100. area 500.) (ssdel e ss)) ) ) -1 ) ) (sssetfirst nil ss) (princ) ) What do I type in the command line to activate that lisp? Thanks for that Quote
ReMark Posted June 3, 2010 Posted June 3, 2010 Type in what is shown immediately after c: which in this case would be the letters qs. Quote
Lee Mac Posted June 3, 2010 Posted June 3, 2010 The link in my signature should explain everything. Quote
