gsksun4 Posted June 8, 2010 Share Posted June 8, 2010 Anybody ever see horizontal grid lines behind text (attributes) in a drawing? They don't print out and can't be erased. Thoughts on how to eliminate them? See attached: Glenn 2009LT GRID-LINES.dwg Quote Link to comment Share on other sites More sharing options...
rvpas Posted June 8, 2010 Share Posted June 8, 2010 Hi, I just open your drawing, I opened the block with attribute and I noticed the grey lines belongs to the block. To fix it, select your attribute right click, choose block editor to open it, erase grey lines and close block editor. That's it Bye Pascal Quote Link to comment Share on other sites More sharing options...
gsksun4 Posted June 8, 2010 Author Share Posted June 8, 2010 Hi,I just open your drawing, I opened the block with attribute and I noticed the grey lines belongs to the block. To fix it, select your attribute right click, choose block editor to open it, erase grey lines and close block editor. That's it Bye Pascal Worked fine. Thank you Pascal. Glenn Quote Link to comment Share on other sites More sharing options...
