Results 1 to 6 of 6
    Senior Member ziemerd's Avatar
    ziemerd's Computer Details
    XP
    HP
    Architecture 2011
    Sep 2004
    Waterloo, IA
    413
    Default Roll Over Problem
    When I roll over a block it's suppose to change the objects of the blocks to thicken. For some reason that is not happening with a particular set of blocks. I tried to draw a line starting at the center of the block but the osnap couldn't see the center of the circle. Does anyone know what's going on?
    Thanks.
    Dawn
    XP
    HP
    Architecture 2011
    Sep 2004
    Waterloo, IA
    413
    I just noticed while trying to roll over a block that there was a tiny little padlock. Is there a way to a block? If so how do I unlock my blocks?
    Thanks.
    Dawn
    XP
    HP
    Architecture 2011
    Sep 2004
    Waterloo, IA
    413
    Ok...It looks like the layer was locked which is strange because other things on that layer did not act the same way. But anyway, I unlocked the layer but I am still having trouble with these particular blocks. I still cannot draw a line snapping to the center of a circle in the block.
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,194
    Could you post the block or an example drawing with the problem block?
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  5. #5
    XP
    HP
    Architecture 2011
    Sep 2004
    Waterloo, IA
    413
    Ok...now it's working. All I did is to delete everything not needed trying to get the drawing as small as possible to upload it but something happened and now it works. I'm not sure what happened.
  6. #6
    Civil 3D 2013
    Apr 2008
    6,194
    Quote Originally Posted by ziemerd View Post
    As long as you're happy.
    DropBox
  1. Roll feed
    By Designer in forum AutoCAD General
    Last Post: 7th Oct 2007, 05:49 am
  2. Metal Roll up door
    By Seb17 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Oct 2007, 05:45 am
  3. set up plotter for continuous roll?
    By jsf252 in forum AutoCAD General
    Last Post: 18th Jun 2007, 05:13 pm
