How do I set a definition as the last object selected without having a command active?
excuse my simple lisp example:
(command "_move" "L"
In this example I'm just pointing out what I mean by last object.
Allen,
I'm sure it's in the files you shared with me but I wasn't able to find it
  • Replies 28
  • Lt Dan's legs
    14
  • alanjt
    9
  • Lee Mac
    4
  • lpseifert
    1
"L" doesn't provide you with the last object selected, it provides you with the last entity created; also accessed with (entlast)
eh...I am not familiar with Lisp at all so forgive me if I stumble into something I don't know - but if you hit P and the "select objects"-prompt you get the last (previous) selection..is that what you are after?
(ssget "_P")
FYI: Alan :wink:
FYI: Alan :wink:
Sorry for that. The sun was in my eyes
___
It made me laugh when I tried to do a quick reply and a message pops up
Sending quick reply - please wait
No biggie. It doesn't bother me; I just wanted to eliminate the mix-up from the beginning.
Did that get you what you wanted?
It came up with
; error: syntax error
should it be as simple as (setq x (ssget "_P"))
It came up with
Works fine on my end. Check for typos.
I think my problem was (( )).. now I get
; error: bad argument type: consp
okay I'm trying to edit this code. this code is exactly what I need but instead of selecting a line with the mouse I want to select the previous object.
Code writen by Terry Miller
; Program Name: DPL - Dimension Polylines
; Created By: Terry Miller (Email: [email="terrycadd@yahoo.com"]terrycadd@yahoo.com[/email])
; (URL: [url]http://web2.airmail.net/terrycad[/url])
; Date Created: 5-20-08
; Function: Dimensions Polyline shapes
; Revision History
; Rev By Date Description
; 1 TM 5-20-08 Initial version
; c:DPL - Dimensions Polyline
(defun c:DPL (/ EntName^ EntPick@)
(setvar "CMDECHO" 0)
(if (setq EntPick@ (entsel "\nSelect Polyline to dimension: "))
(if (= (cdr (assoc 0 (entget (car EntPick@)))) "LWPOLYLINE")
(setq EntName^ (cdr (assoc -1 (entget (car EntPick@)))))
(DimPL EntName^)
);progn
);if
);if
(if (not EntName^)
(princ "\nNo Polyline selected.")
);if
);defun c:DPL
; DimPL - Function to dimension Polyline
; Arguments: 1
; EntName^ = Polyline entity name
; Returns: Dimensions Polyline
(defun DimPL (EntName^ / Bottom@ Clayer$ CW# DiffAng DimPts: DimSpace~ EntList@
Item LastAng~ LastPt Left@ List@ NW@ Osmode# P0 P1 P2 Pt Pts@ PtsLen Right@ SE@
Top@ X~ X1~ X1Y1 X1Y2 X1Ys@ X2~ X2Y1 X2Y2 X2Ys@ XPts@ Y~ Y1~ Y1X1 Y1X2 Y1Xs@ Y2~
Y2X1 Y2X2 Y2Xs@ YPts@)
(defun DimPts: (Pts@ StartPt EndPt Type$ / Add Num1~ Num2~ Nums1@ Nums2@ P1 P2
Pt Return@)
(setq Add t)
(foreach Pt (member StartPt (append Pts@ Pts@))
(if Add
(setq Return@ (append Return@ (list Pt)))
);if
(if (equal Pt EndPt)
(setq Add nil)
);if
);foreach
(foreach Pt Return@
(if (member Type$ (list "Left" "Right"))
(setq Nums1@ (append Nums1@ (list (cadr Pt))))
(setq Nums1@ (append Nums1@ (list (car Pt))))
);if
);foreach
(foreach Num1~ (vl-sort Nums1@ '<)
(setq Nums2@ nil)
(foreach Pt Return@
(if (= (cadr Pt) Num1~)
(setq Nums2@ (append Nums2@ (list (car Pt))))
);if
(if (= (car Pt) Num1~)
(setq Nums2@ (append Nums2@ (list (cadr Pt))))
);if
);if
);foreach
(if (member Type$ (list "Left" "Bottom"))
(setq Nums2@ (vl-sort Nums2@ '<))
(setq Nums2@ (reverse (vl-sort Nums2@ '<)))
);if
(foreach Num2~ (cdr Nums2@)
(setq Pt (list Num2~ Num1~))
(setq Pt (list Num1~ Num2~))
);if
(setq Return@ (vl-remove Pt Return@))
);foreach
);foreach
(cond
((= Type$ "Left")
(vl-sort Return@ (function (lambda (P1 P2)(< (cadr P1)(cadr P2)))))
);case
((= Type$ "Top")
(vl-sort Return@ (function (lambda (P1 P2)(< (car P1)(car P2)))))
);case
((= Type$ "Right")
(vl-sort Return@ (function (lambda (P1 P2)(> (cadr P1)(cadr P2)))))
);case
((= Type$ "Bottom")
(vl-sort Return@ (function (lambda (P1 P2)(> (car P1)(car P2)))))
);case
);cond
);defun DimPts:
(setq EntList@ (entget EntName^))
(if (= (cdr (assoc 0 EntList@)) "LWPOLYLINE")
(foreach List@ EntList@
(if (= (car List@) 10)
(if (not (equal (cdr List@) LastPt))
(setq Pts@ (append Pts@ (list (cdr List@))))
(if (> (length Pts@) 2)
(if (/= (angle LastPt (cdr List@)) LastAng~) (setq DiffAng t))
);if
(if (> (length Pts@) 1)
(setq LastAng~ (angle LastPt (cdr List@)))
);if
(setq LastPt (cdr List@))
);progn
);if
);if
);foreach
(if (equal (car Pts@) (last Pts@))
(setq Pts@ (reverse (cdr (reverse Pts@))))
);if
(setq PtsLen (length Pts@))
);progn
(exit)
);if
(foreach Pt Pts@
(setq X~ (atof (rtos (car Pt) 2 )
Y~ (atof (rtos (cadr Pt) 2 )
XPts@ (append XPts@ (list X~))
YPts@ (append YPts@ (list Y~))
Pts@ (cdr (append Pts@ (list (list X~ Y~))))
);setq
);foreach
(setq XPts@ (vl-sort XPts@ '<)
YPts@ (vl-sort YPts@ '<)
X1~ (car XPts@)
X2~ (last XPts@)
Y1~ (car YPts@)
Y2~ (last YPts@)
);if
(foreach Pt Pts@
(if (= (car Pt) X1~) (setq X1Ys@ (append X1Ys@ (list (cadr Pt)))))
(if (= (car Pt) X2~) (setq X2Ys@ (append X2Ys@ (list (cadr Pt)))))
(if (= (cadr Pt) Y1~) (setq Y1Xs@ (append Y1Xs@ (list (car Pt)))))
(if (= (cadr Pt) Y2~) (setq Y2Xs@ (append Y2Xs@ (list (car Pt)))))
);foreach
(setq X1Ys@ (vl-sort X1Ys@ '<)
X2Ys@ (vl-sort X2Ys@ '<)
Y1Xs@ (vl-sort Y1Xs@ '<)
Y2Xs@ (vl-sort Y2Xs@ '<)
X1Y1 (list X1~ (car X1Ys@))
X1Y2 (list X1~ (last X1Ys@))
X2Y1 (list X2~ (car X2Ys@))
X2Y2 (list X2~ (last X2Ys@))
Y1X1 (list (car Y1Xs@) Y1~)
Y1X2 (list (last Y1Xs@) Y1~)
Y2X1 (list (car Y2Xs@) Y2~)
Y2X2 (list (last Y2Xs@) Y2~)
Pts@ (member X1Y1 (append Pts@ Pts@))
);setq
(while (> (length Pts@) PtsLen)
);while
(setq SE@ (member X2Y2 Pts@) NW@ Pts@)
(foreach Item SE@
(setq NW@ (vl-remove Item NW@))
);foreach
(setq SE@ (append SE@ (list X1Y1))
NW@ (append NW@ (list X2Y2))
CW# 0
);setq
(foreach Pt (list Y2X1 Y2X2)
(if (member Pt NW@) (setq CW# (1+ CW#)))
(if (member Pt SE@) (setq CW# (1- CW#)))
);foreach
(foreach Pt (list Y1X1 Y1X2)
(if (member Pt SE@) (setq CW# (1+ CW#)))
(if (member Pt NW@) (setq CW# (1- CW#)))
);foreach
(if (< CW# 0)
(setq Pts@ (append (list (car Pts@))(reverse (cdr Pts@))))
);if
(setq Left@ (DimPts: Pts@ Y1X1 Y2X1 "Left"))
(setq Top@ (DimPts: Pts@ X1Y2 X2Y2 "Top"))
(setq Right@ (DimPts: Pts@ Y2X2 Y1X2 "Right"))
(setq Bottom@ (DimPts: Pts@ X2Y1 X1Y1 "Bottom"))
(command "UNDO" "BEGIN")
(setq DimSpace~ (* (getvar "DIMSCALE") (getvar "DIMTXT") 3))
(setq Osmode# (getvar "OSMODE")) (setvar "OSMODE" 0)
(setq Clayer$ (getvar "CLAYER"))
(command "LAYER" "S" "DIM" "");<--Change to your Dim layer info
(setq P0 (polar X1Y1 pi (* DimSpace~ 1.5))
P1 (car Left@)
);setq
(foreach P2 (cdr Left@)
(command "DIM1" "VER" P1 P2 P0 "")
(setq P1 P2)
);foreach
(if (> (length Left@) 2)
(setq P0 (polar P0 pi DimSpace~))
(command "DIM1" "VER" (car Left@) (last Left@) P0 "")
);progn
);if
(setq P0 (polar Y2X1 (* pi 0.5) (* DimSpace~ 1.5))
P1 (car Top@)
);setq
(foreach P2 (cdr Top@)
(command "DIM1" "HOR" P1 P2 P0 "")
(setq P1 P2)
);foreach
(if (> (length Top@) 2)
(setq P0 (polar P0 (* pi 0.5) DimSpace~))
(command "DIM1" "HOR" (car Top@) (last Top@) P0 "")
);progn
);if
(setq P0 (polar X2Y2 0 (* DimSpace~ 1.5))
P1 (car Right@)
);setq
(if (and (> (length Right@) 2) DiffAng)
(foreach P2 (cdr Right@)
(setq P1 P2)
);foreach
);if
(setq P0 (polar Y1X2 (* pi 1.5) (* DimSpace~ 1.5))
P1 (car Bottom@)
);setq
(if (and (> (length Bottom@) 2) DiffAng)
(foreach P2 (cdr Bottom@)
(setq P1 P2)
);foreach
);if
(setvar "CLAYER" Clayer$)
(setvar "OSMODE" Osmode#)
(command "UNDO" "END")
);defun DimPL
; GetDimLayer - Returns the layer name that's on and has the most dimensions,
; or the current layer name if there's no dimensions.
(defun GetDimLayer (/ DimLayer$ EntList@ Index# Layer$ LayerInfo@ LayerList@ List@ Num# SS&)
(setq Layer$ (getvar "CLAYER"))
(if (setq SS& (ssget "X" '((0 . "DIMENSION"))))
(setq Index# -1)
(while (< (setq Index# (1+ Index#)) (sslength SS&))
(setq EntList@ (entget (ssname SS& Index#))
DimLayer$ (cdr (assoc 8 EntList@))
LayerInfo@ (tblsearch "LAYER" DimLayer$)
);setq
(if (and (= (cdr (assoc 70 LayerInfo@)) 0)(> (cdr (assoc 62 LayerInfo@)) 0))
(if (assoc DimLayer$ LayerList@)
(setq Num# (1+ (cdr (assoc DimLayer$ LayerList@)))
LayerList@ (subst (cons DimLayer$ Num#) (assoc DimLayer$ LayerList@) LayerList@)
);setq
(setq LayerList@ (append LayerList@ (list (cons DimLayer$ 1))))
);if
);if
);while
(if LayerList@
(setq Layer$ (car (car LayerList@))
Num# (cdr (car LayerList@))
);setq
(foreach List@ (cdr LayerList@)
(if (> (cdr List@) Num#)
(setq Layer$ (car List@)
Num# (cdr List@)
);setq
);if
);foreach
);progn
);if
);progn
);if
Layer$
);defun GetDimLayer
(princ);End of DPL.lsp
two examples (completely untested):
(defun c:one (/ ss)
 (if (setq ss (ssget "_P" '((0 . "LWPOLYLINE"))))
   (DimPL (ssname ss 0))
(defun c:all (/ ss)
   ((lambda (i)
      (while (setq e (ssname ss (setq i (1+ i))))
        (DimPL e)
     -1
Works great! thanks
1. How do I get the block to display when I'm using VL? I want it do display the block when the command prompts select insertion point.
2. When attedit command runs in lisp it displays on the command prompt. How do I change that?
  1. You would have to use GrRead to emulate and you'll have to emulate OSnaps also' date=' or use the command.
    [*'](initdia)
  1. You would have to use GrRead to emulate and you'll have to emulate OSnaps also, or use the command.
  2. (initdia)
Thank you sir
Perhaps acet-ss-drag-move
....or that.
I found an example of grread that you created. It helped me out. How did you get perpendicular to work on your numinc program? I searched for acer-ss-drag-move and could not find it anywhere in that program.
Perpendicular?
