Barn Light Posted June 17, 2010 Share Posted June 17, 2010 Hello all, is there a way to remove or change the hole in this solid? The power went out and the system went down so undo is not an option. I created the hole by subtracting a cylinder from the solid.I know I could have altered my cylinder in properties before the subtraction but how can I do it after I make the subtraction? Thanks in advace. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 17, 2010 Share Posted June 17, 2010 See the solidedit tools. F1 You can change the size (offset + or -), move or even delete the hole. Quote Link to comment Share on other sites More sharing options...
