KStatefan Posted June 21, 2010 Posted June 21, 2010 I have an arc that is a number of short straight lines. Is there a way to convert the line segments to an arc? Quote
eldon Posted June 21, 2010 Posted June 21, 2010 If you use Pedit to join all the straight lines into one polyline, and then Fit curve. One trouble there is that you would have as many arcs as you had short lines. Perhaps another approach would be to draw a new arc using three points, and then erase all the little lines. Quote
JD Mather Posted June 21, 2010 Posted June 21, 2010 If it is truelly an arc (part of a circle) rather than a general curve represented by lines then simply circle (or arc) with three points. Delete the lines. Quote
KStatefan Posted June 21, 2010 Author Posted June 21, 2010 I was trying to not have to draw all of them. Each arc is really made up of three or four arcs. Quote
JD Mather Posted June 21, 2010 Posted June 21, 2010 I was trying to not have to draw all of them. Each arc is really made up of three or four arcs. Someone out there might have a lisp, but my question is, "Which lines go with which arcs?" That question is a lot easier for a human to answer than it is for a machine. Think about how you would code that.... Quote
alanjt Posted June 21, 2010 Posted June 21, 2010 Quick and CLUNKY... Will only work on one set at a time. (defun c:test (/ ss eLast ent) (vl-load-com) (if (setq ss (ssget "_:L" '((0 . "ARC")))) (progn (setq eLast (entlast)) (if (eq (getvar 'peditaccept) 1) (vl-cmdf "_.pedit" "_m" ss "" "_j" "" "") (vl-cmdf "_.pedit" "_m" ss "" "_y" "_j" "" "") ) (or (eq eLast (setq ent (entlast))) ((lambda (pts) (vl-cmdf "_.arc" "_non" (car pts) "_non" (nth (/ (length pts) 2) pts) "_non" (last pts)) (entdel ent) ) (mapcar (function cdr) (vl-remove-if-not (function (lambda (x) (eq 10 (car x)))) (entget ent)) ) ) ) ) ) (princ) ) Quote
KStatefan Posted June 21, 2010 Author Posted June 21, 2010 Thanks for the suggestions. I am going to manually get them like I want. Quote
