Running a lisp Command from VBA with a pause
I have a lisp command that I use to insert blocks (either Dynamic or regular)
(C:BBREAK) it asks for an insertion point on a line, then block name, then if its a dynamic block whats the visibility parameter value. Then it inserts the block and breaks the line out based on an attribute value in the block.
Typical macro usage looks like this for a dynamic block EB020.dwg with visibility parameter "NO"
bbreak;\EB020;y;NO;
My problem is I would like to run this lisp program from VBA also
I thought I could use ThisDrawing.SendCommand but how do I pause for user input of the insertion point on a line.
