FlipRocket Posted June 27, 2010 Share Posted June 27, 2010 Hi, this is my first post on theses forums. I just started learning AutoCAD. I had a small project to do for one of my classes, which was just to draw a simple 2D house plan. So just for fun, I'd like to make my house 3D. I don't know if it's the best way to do it, but here's what I did so far: First I changed the Thickness property of the walls on my plan, then I did the same with my windows and moved them along the Z axis (using the properties window) to raise them from the floor. I also used the 3dface command to close off the top of my walls and windows. Now, how can I make the window-sized hole in my wall? I tried to use the subtract command, but that doesn't seem to work. Thank you in advance for your answers! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 27, 2010 Share Posted June 27, 2010 Now, how can I make the window-sized hole in my wall? I tried to use the subtract command, but that doesn't seem to work. You must be doing something wrong. Subtract is how you cut holes in objects. Can you explain the procedure you used while trying to Subtract? Screenshots would also helpful, so we can see what you've done and what you're trying to do. Also, from your description, it sounds like you created your walls with Surfaces. You should be using Solids. Quote Link to comment Share on other sites More sharing options...
FlipRocket Posted June 27, 2010 Author Share Posted June 27, 2010 I just set the thickness of the lines from my 2d plan to the height of the wall. And then I was trying to make a hole in that wall using subtract. But I guess that's not the way to do it? I will give it a shot with solids. Sorry I am a noob at this... Here's a screenshot. Quote Link to comment Share on other sites More sharing options...
bastymydawg Posted June 27, 2010 Share Posted June 27, 2010 you could try using presspull, highlight the inner part of your window and drag on the opposite side. Quote Link to comment Share on other sites More sharing options...
Dorian Posted June 27, 2010 Share Posted June 27, 2010 I would recommend you to use the BOX solid, it'll get you going a lot faster because its more editable than the other methods. Quote Link to comment Share on other sites More sharing options...
rvpas Posted June 27, 2010 Share Posted June 27, 2010 Hi, For your walls, you can use Polysolid (1) Home tab/modeling panel/polysolid you can change its Height [Height]: h you can change its width [Width]: w you can its justification [Justify]: j for opening for doors and windows, you can use press/pull (3) after to draw your opening by using dynamic UCS (2) see image Bye Pascal Quote Link to comment Share on other sites More sharing options...
FlipRocket Posted June 27, 2010 Author Share Posted June 27, 2010 thank you rvpas, I will try that Quote Link to comment Share on other sites More sharing options...
New2CADmike Posted June 29, 2010 Share Posted June 29, 2010 You used the properties box to add thickness?..so you actually didn't extrude it to create solids ,did you?Maybe that is the reason solids modify commands don't work..you are not working with solids.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2010 Share Posted June 29, 2010 You can create solid walls with the Extrude, Press/Pull, Loft and Polysolid commands. You can create openings for your doors and windows using Subtract or Press/Pull. Quote Link to comment Share on other sites More sharing options...
FlipRocket Posted June 30, 2010 Author Share Posted June 30, 2010 yes indeed I wasnt working with solids... the polysolid command along with presspull works really well to create walls Quote Link to comment Share on other sites More sharing options...
