Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Junior Member
    Inventor 2011
    Oct 2009
    21
    Default Inventor 2011 to AutoCAD
    Hello,
    I am using Inventor 2011. Our company does a lot of sheet metal laser cutting. So we send AutoCAD drawings to the manufacturer. I know how to tranfer the drawing from Inventor 2011 to AutoCAD. However, all the drawings end up on the Layout page in AutoCAD.
    Our manufacturer requires all drawings on the Model Page instead. So I end up drawing the 2D sheet metal on the Model page which for me is a waste of time.
    Is there a way to export the drawings from Inventor 2011 right to the Model page in AutoCAD.
    Thanks in advance.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Export the flat pattern face from ipt (not idw).
    Senior Member
    ecshclark's Computer Details
    Window 7 Pro, 64 Bit (Service Pack 1)
    Dell Precision Tower 5810
    Intel(R) Xeon(R) CPU E5-1650 v3 @ 3.50GHz (6 CPUs), 3.5GH
    32.00 GB
    NVIDIA Quadro K2200
    Wasabi Mango QHD275 Universal 27" Dual Monitors
    Mechanical
    ecshclark's Discipline Details
    Engineer - Retail & Digital Displays, Fixtures, Kiosks, A//V
    Mechanical
    Inventor 2018
    Apr 2010
    Mesick, MI
    122
    Go to Save As,
    Select Save Copy As,
    In the dialog box in Save as type select AutoCAD Drawings
    Click Options... button
    Select AutoCAD file version, go to next,
    Under Export Options, Data Scaling, Select the scale that suits your need:
    Base View Scale - Model Space
    Sheet Scale - Model Space
    Full Scale (1:1) - Model Space
    It is are probably defaulting to a layout scale right now.
    I'm on 2010 right now, but I would imagine 2011 is the same.
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    759
    Quote Originally Posted by JD Mather View Post
    That's how I do it for our waterjet... easy and fast.
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
  5. #5
    Junior Member
    Inventor 2011
    Oct 2009
    21
    Quote Originally Posted by ecshclark View Post
    Go to Save As,
    Thanks. That helped. I tried it and it worked perfect!
  6. #6
    Forum Newbie
    Mechanical 2010
    Jan 2011
    1
    Thanks very much to all those who posted/replied above.
    You have very likely just solved a very similar and serious problem for me as well that has stumped me for a day and a half (my problem was exporting sheet metal folded object from Inventor to Autocad Mechanical model space and currently ending up with it in layout space only with inability to edit/ copy etc.). I will have to try this as unfolded part as directed above.
  7. #7
    Full Member
    dshowalt's Computer Details
    Windows 7 64-bit
    Intel i7
    8GB
    Nvidia
    Education
    dshowalt's Discipline Details
    Education
    Education
    Inventor 2012
    Dec 2009
    Kansas City, USA
    57
    If you do ger objects in paperspace by mistake you can use CHSPACE comand in AutoCAD to move them to Model Space
  8. #8
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by Doodles View Post
    .... (my problem was exporting sheet metal folded object from Inventor to Autocad Mechanical model space.... I will have to try this as unfolded part as directed above.
    Environments>AEC Exchange - Save as DWG Solid.
  9. #9
    Senior Member
    AutoCAD 2013
    Apr 2009
    EU
    248
    Hi,
    I want to save an .IAM file to .DWG , I'm using Inventor 2013, there is no AEC Exchange anymore
  10. #10
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    You can save it to dwg directly now, no need to go to AEC Exchange anymore.
  1. Inventor 2010 and 2011?
    By facad in forum Autodesk Inventor
    Last Post: 25th Jun 2010, 11:19 pm
  2. inventor 2011
    By Viktorik in forum Autodesk Inventor
    Last Post: 9th Jun 2010, 10:36 pm
  3. Inventor 2011
    By IronHorse in forum Autodesk Inventor
    Last Post: 11th May 2010, 12:32 pm
  4. AutoCAD 2011 and many other Autodesk 2011 Products Released.
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 25th Mar 2010, 02:46 pm
