EGoldberg Posted July 6, 2010 Share Posted July 6, 2010 All, I'm looking for a little help with plotting specific paper sizes in VBA. I'm writing a program that gives the drafters in our group a little flexibility. The program allows them to pick available plotters from a list and then allows them to set up what paper sizes they want printed where. For instance, A size: InkJet 1 (8.5x11), B size: InkJet 1 (11x17), C size: Oce Plotter (... etc etc). All the drawings selected, if they are a certain size should then be plotted to the predetermined plotter. I can get it to print to the proper printer but I don't know how to set the proper paper size. I've demonstrated an ability to do it using sendcommand, but I know that's poor programming. Is there a way of plottingtodevice using a specific available paper size? Quote Link to comment Share on other sites More sharing options...
EGoldberg Posted July 6, 2010 Author Share Posted July 6, 2010 Well I figured out how to do that part. Now I just need to figure out how to get the program to wait long enough for the previous job to print before going onto the next one. Quote Link to comment Share on other sites More sharing options...
EGoldberg Posted July 6, 2010 Author Share Posted July 6, 2010 Disregard this entirely... figured it out. Quote Link to comment Share on other sites More sharing options...
Kerry Brown Posted July 7, 2010 Share Posted July 7, 2010 Disregard this entirely... figured it out. That's great. For those following, what was the solution you arrived at ?? Quote Link to comment Share on other sites More sharing options...
EGoldberg Posted July 8, 2010 Author Share Posted July 8, 2010 I just typed a whole nice description up with details and everything but because there was links to my source info and I have 8 posts instead of the 9 necessary to post links; I lost everything. I don't really have the time to go into detail again but if you have any questions, please let me know. Basically I use two user forms. One contains a list of all the drawings and sizes, the other contains labels that store the plotter info and the paper sizes available to each plotter and what was selected for size A, B, C, D, and E. Using that info, the plotter info is compared to the size of the drawing and plotted to the correct plotter. Userform1 - code snippet For I = ListBox1.ListCount - 1 To 0 Step -1 If ListBox1.Selected(I) = True Then tdd = Split(ListBox1.list(I), " - ") If tdd(2) <> "Size: Unknown!" Then Application.Documents(tdd(0)).Activate Thisdrawing.ActiveLayout = Thisdrawing.Layouts(tdd(1)) sze = Right(tdd(2), 1) var_BGPlot = Thisdrawing.GetVariable("BACKGROUNDPLOT") Thisdrawing.SetVariable "BACKGROUNDPLOT", 0 bResult = True getBackPlot = bResult Select Case sze Case "A" pltps = Split(PSS.Label9.Caption, " - ") Case "B" pltps = Split(PSS.Label10.Caption, " - ") Case "C" pltps = Split(PSS.Label11.Caption, " - ") Case "D" pltps = Split(PSS.Label12.Caption, " - ") Case "E" pltps = Split(PSS.Label13.Caption, " - ") End Select Thisdrawing.PlotConfigurations.Add "TESTPC2", True Thisdrawing.ActiveLayout.ConfigName = pltps(0) Thisdrawing.PlotConfigurations.Item("TESTPC2").ConfigName = pltps(0) Thisdrawing.ActiveLayout.StyleSheet = "NU-STD.stb" Thisdrawing.PlotConfigurations.Item("TESTPC2").StyleSheet = "NU-STD.stb" cmn = Thisdrawing.ActiveLayout.GetCanonicalMediaNames For qq = 0 To UBound(cmn) lcn = Thisdrawing.ActiveLayout.GetLocaleMediaName(cmn(qq)) If lcn = pltps(1) Then Thisdrawing.ActiveLayout.CanonicalMediaName = cmn(qq) Thisdrawing.PlotConfigurations.Item("TESTPC2").CanonicalMediaName = cmn(qq) Thisdrawing.ActiveLayout.StandardScale = acScaleToFit Thisdrawing.PlotConfigurations.Item("TESTPC2").StandardScale = acScaleToFit Thisdrawing.ActiveLayout.CenterPlot = True Thisdrawing.PlotConfigurations.Item("TESTPC2").CenterPlot = True Thisdrawing.ActiveLayout.RefreshPlotDeviceInfo Thisdrawing.ActiveLayout.RefreshPlotDeviceInfo Thisdrawing.PlotConfigurations.Item("TESTPC2").RefreshPlotDeviceInfo Thisdrawing.ActiveLayout.RefreshPlotDeviceInfo Thisdrawing.Plot.PlotToDevice pltps(0) '"TESTPC2" Thisdrawing.ActiveLayout.RefreshPlotDeviceInfo Thisdrawing.PlotConfigurations.Item("TESTPC2").Delete Thisdrawing.SetVariable "BACKGROUNDPLOT", var_BGPlot End If Next End If End If Next I Userform(2) PSS Private Declare Function GetProfileString Lib "kernel32" _ Alias "GetProfileStringA" _ (ByVal lpAppName As String, _ ByVal lpKeyName As String, _ ByVal lpDefault As String, _ ByVal lpReturnedString As String, _ ByVal nSize As Long) As Long Private Const DC_PAPERNAMES = &H10 Private Declare Function DeviceCapabilities _ Lib "winspool.drv" _ Alias "DeviceCapabilitiesA" _ (ByVal lpDeviceName As String, _ ByVal lpPort As String, _ ByVal iIndex As Long, _ ByRef lpOutput As Any, _ ByRef lpDevMode As Any) _ As Long Private Declare Function StrLen _ Lib "kernel32.dll" _ Alias "lstrlenA" _ (ByVal lpString As String) _ As Long Private Sub CommandButton1_Click() If ListBox1.ListIndex > -1 And ListBox2.ListIndex > -1 Then If CheckBox1.value = True Then Label9.Caption = ListBox1.value & " - " & ListBox2.value ElseIf CheckBox2.value = True Then Label10.Caption = ListBox1.value & " - " & ListBox2.value ElseIf CheckBox3.value = True Then Label11.Caption = ListBox1.value & " - " & ListBox2.value ElseIf CheckBox4.value = True Then Label12.Caption = ListBox1.value & " - " & ListBox2.value ElseIf CheckBox5.value = True Then Label13.Caption = ListBox1.value & " - " & ListBox2.value End If End If End Sub Private Sub CommandButton2_Click() PSS.Hide End Sub Private Sub Label5_Click() End Sub Private Sub ListBox1_Click() ListBox2.Clear Call WinNTSetDefaultPrinterAvailPS End Sub Private Sub UserForm_Initialize() Dim r As Long Dim Buffer As String ' Get the list of available printers from WIN.INI Buffer = Space(8192) r = GetProfileString("PrinterPorts", vbNullString, "", _ Buffer, Len(Buffer)) ' Display the list of printer in the ListBox List1 ParseList ListBox1, Buffer End Sub Private Sub ParseList(lstCtl As Control, ByVal Buffer As String) Dim I As Integer Dim s As String Do I = InStr(Buffer, Chr(0)) If I > 0 Then s = Left(Buffer, I - 1) If Len(Trim(s)) Then lstCtl.AddItem s Buffer = Mid(Buffer, I + 1) Else If Len(Trim(Buffer)) Then lstCtl.AddItem Buffer Buffer = "" End If Loop While I > 0 End Sub Private Sub GetDriverAndPort(ByVal Buffer As String, DriverName As _ String, PrinterPort As String) Dim iDriver As Integer Dim iPort As Integer DriverName = "" PrinterPort = "" ' The driver name is first in the string terminated by a comma iDriver = InStr(Buffer, ",") If iDriver > 0 Then ' Strip out the driver name DriverName = Left(Buffer, iDriver - 1) ' The port name is the second entry after the driver name ' separated by commas. iPort = InStr(iDriver + 1, Buffer, ",") If iPort > 0 Then ' Strip out the port name PrinterPort = Mid(Buffer, iDriver + 1, _ iPort - iDriver - 1) End If End If End Sub Private Sub WinNTSetDefaultPrinterAvailPS() Dim Buffer As String Dim DeviceName As String Dim DriverName As String Dim PrinterPort As String Dim PrinterName As String Dim r As Long If ListBox1.ListIndex > -1 Then ' Get the printer information for the currently selected ' printer in the list. The information is taken from the ' WIN.INI file. Buffer = Space(1024) PrinterName = ListBox1.Text r = GetProfileString("PrinterPorts", PrinterName, "", _ Buffer, Len(Buffer)) ' Parse the driver name and port name out of the buffer GetDriverAndPort Buffer, DriverName, PrinterPort x = Buffer & " " & DriverName & " " & PrinterPort ' ListBox2.AddItem x PD = PrinterName PD1 = DriverName Ret = DeviceCapabilities(PD, PD1, DC_PAPERNAMES, ByVal 0&, ByVal 0&) 'resize the array ReDim PaperSizes(0 To Ret * 64) As Byte 'retrieve all the available paper names Call DeviceCapabilities(PD, PD1, DC_PAPERNAMES, PaperSizes(0), ByVal 0&) 'convert the retrieved byte array to an ANSI string AllNames = StrConv(PaperSizes, vbUnicode) 'loop through the string and search for the names of the papers For I = 1 To Len(AllNames) Step 64 PaperSize = Mid(AllNames, I, 64) PaperSize = Left(PaperSize, StrLen(PaperSize)) ' Msg = Msg & PaperSize & vbCrLf If InStr(LCase(PaperSize), "custom") = 0 Then ListBox2.AddItem PaperSize End If Next I 'MsgBox "Supported Paper Sizes:" & vbCrLf & vbCrLf & Msg, vbOKOnly, PD0 End If End Sub Do note that my code eliminates "custom" sized paper. Let me know if you have any questions. And again, sorry for the lack of details but I just don't have the time to explain again right now :-/ Quote Link to comment Share on other sites More sharing options...
